Direct Port LS2 GTO, 56K Death!
#41
I couldn't do the same bends for each cyl because every other nozzle is reversed. (because they are in the runners)
Originally Posted by distinctdev
its probably negligible but the lines on every other cylinder are longer then the next... why didnt you use the same bends for each cylinder?
#42
Originally Posted by Noyzee
and it ran??
did you do the converter yet??
I made a few NA passes last week, best being a 13.7, which isn't so hot. I was having a problem with the ABS, which limits how much you can bring up the RPM's while braking, so the launches were real soft. I'm begining to really dislike drive by wire. Anyway, the ABS issue is fixed and I'm ready to run it with spray now, but its raining and the track is closed.
Vinny
#45
Originally Posted by 860 Performance
The funny thing is I brought it in to a pontiac Dlr for an alignment. They put it on the rack, measured it and said it was within spec. So they never opened the hood.
They did however give me my paperwork with a pile of rubber on it, and said the rubber was from my rear wheel wells.
Install looks good
Looking forward to seeing it make some passes on Wednesday at NED.
Hey Scalmaster - nice sig
#50
#51
Yeah the 2 ports are specific, here is a link to NX's catalog that has a cross section you can see.
http://www.nitrousexpress.com/Catalo...zzlesystem.pdf
#52
vin, after seeing your car in person, pics look like ****!!!
great job for sure. slick and sick!!!
Today was a good day at the track,
1 nitrous pass 11.9@122!!!!!!, and that was with a 2.0 60ft! Stock tires at 35 psi too!!!
#53
Thanks Brad!
BTLFEDSS
#60
Originally Posted by onelife
Correct me if I'm wrong but one of the main reasons to do direct port is to place the nozzles as close as possible to the intake port?
My preference is to pull them back giving it a chance to fan out some before entering the head.
Vinny
