WOT via TPS not working?
I have a nitrous outlet window / wot switch connected to tps
Step 7 is set to 002 TPS signal to PCM.
Step 8 shows 8:4.2 runnig at idle
and it goes to 8:04 after a driving wot blast it saves the 8:04 and says end...
but the kit is activating under any throttle in the set 3-6k window
(I have the 50 jets in and the bottle closed for testing)
Just sitting it displays 000 if I touch the gas it shows 100
What am I doing wrong?
Sorry it is a 2006 C6
TP 1 = pin 65 dark green signal is above 4v at idle and below 1v at WOT
TP 2 = pin 63 purple is below 1v at idle and above 4v at WOT
I am went with the green
Closed ex-Sponsor Account
Hey I got this from LS1GTO.com, maybe this will help.
(I copied it straight off the Post) - Credit Goes to NX Ricky
I was using the one that NX ricky quotes (Blue wire)
04 GTO LS1 TPS at the throttle body BLUE wire. at the computer pin 24 grean seal connector 2. blue wire
TACH coil trigger wire light green passenger side, at the computer pin 10 green seal connector 2. brown wire
05 GTO LS2 tps at the computer pin 31 green for falling black connector. tps at the throttle body Green wire
tach coil trigger wire light green passenger side., at the computer pin 48 blue connector 1 Brown wire I believe..
Someone might want to check me on this.
Ricky"
Ricky"
