Tips How To Make It Look Better
Old Apr 28, 2007 | 01:30 AM
ShaneD_06GTO's Avatar
Default Tips How To Make It Look Better
I ordered a shorter fuel line, but ordered a blue fitting line instead of a red fitting.
Here's how it looked before.
Here's my setup after I tried to clean it up a bit.
How can I make this look cleaner? Solenoid position, line position, line coverings, etc. I need your guys' help!
Thanks,
Shane
Old Apr 28, 2007 | 03:23 AM
KrautBurner's Avatar
all depends on what you like
I have the noide at the back of the engine, behind/under the frc's
here's mine: http://nitrousoutlet.com/customerCars/details.asp?id=44
Old Apr 28, 2007 | 01:48 PM
JustAnIlluzion's Avatar
you can order a fitting to mount the fuel solenoid directly on the fuel rail if you have the space
Old Apr 28, 2007 | 04:43 PM
iB2slow's Avatar
LOL this is hard to explain with out showing but ill try. Put noids directly across from each other, Use string to find out the correct lenght of lines so you dont have to route them behinde and under **** just make them equal. Wire loom the feed line hide it cut loom so that both feed lines seem equal. Loom the purge line hide it. Make sence????? Oh and flip the fuel noid around and get new sticker.
Old Apr 28, 2007 | 08:25 PM
Yeah, I was thinking about how to go about looming the wires. It's a good idea to flip the fuel noid around. I'll draw or ps some things and post them up. How do I go about disconnecting the fuel line w/o having fuel go all over?
Old Apr 28, 2007 | 09:15 PM
iB2slow's Avatar
Mine didnt leak to much when I took all my **** off just put a cup under you rail no big deal.
Old Apr 28, 2007 | 09:53 PM
iB2slow's Avatar
Old Apr 28, 2007 | 09:56 PM
iB2slow's Avatar
not the best work but you get the idea move your n20 noids to the circle. feed line is the blue line loom it. just thought it might give you some idea.
Old Apr 29, 2007 | 12:45 AM
That is a good idea. I'll try it and see what I can do. Thanks man. Otherwise I might get a noid plate mount and still loom them.
Old Apr 29, 2007 | 12:55 AM
patriotformula's Avatar
Start by cleaning your engine bay in general... armor all that **** or something, looks real dirty
Old Apr 29, 2007 | 01:08 AM
Yeah, yeah, I'm getting the car fully detailed within the next 2 weeks.
Old Apr 29, 2007 | 01:16 AM
iB2slow's Avatar
Just do a search for install pics it will help you out ALOT by looking at them. Mainly lines same length and not in a birds nest wrapped around **** and hide the feed line.
