Bottle Locations on 98+ F-body...
Old May 5, 2007 | 02:01 AM
whytryz28's Avatar
Default Bottle Locations on 98+ F-body...
Im installing my nitrous kit and was wondering where do you guys have your bottle mounted? 10lb is what im using. Pics would be helpful also...its a street car so i dont want it to be in the way that much. thanks
Old May 5, 2007 | 02:22 AM
BayAreaSS's Avatar
Check out this thread......
https://ls1tech.com/forums/showthrea...t=bottle+mount
Old May 5, 2007 | 02:47 AM
whytryz28's Avatar
you the man
Old May 5, 2007 | 02:48 AM
BayAreaSS's Avatar
Originally Posted by whytryz28
you the man
Naw... i just have done a ton of searching over the past few months!
Old May 5, 2007 | 03:15 AM
whytryz28's Avatar
haha thanks, you wouldnt happen to know the right injector sizes for a 150 wet shot would you? My search isnt working.
Old May 5, 2007 | 03:27 AM
BayAreaSS's Avatar
Are you running a wet or dry kit?
If its a wet kit you wont need to upgrade the injectors. If its a dry then you will most likely need to upgrade the injectors. The size of the injectors depends on your current power level and what future mods you have planned
Old May 5, 2007 | 03:37 AM
whytryz28's Avatar
Oh well its a wet kit so i guess im set, im changing the fuel pump already. Would i need a tune to run it? or i could get away with it?
Old May 5, 2007 | 03:51 AM
BayAreaSS's Avatar
I still pretty new to this so i'm not sure. But if it was me i would at least get on a dyno with the 150 shot and check the AFR. If its not correct i would get a tune.
When i'm ready to spray a 150 shot i will definitely be getting a tune. I'm starting small at a 75 then working my way up.
Old May 5, 2007 | 10:19 AM
2000Hawk's Avatar
Im going to be running a 150 as well. But what im going to do is do my first test run with the 100 set up. If everything checks out ok, then i'll bump it up to 150 so i could get it tuned.
-Joel
Old May 5, 2007 | 10:21 AM
Almostryan3's Avatar
Make sure your running the right spark plugs with the right gapping and make sure you run 100 octane at least.
Old May 5, 2007 | 03:11 PM
BayAreaSS's Avatar
I think 100 octane might be a little over kill for a 100-150 shot....but the safer the better
