WOT switch bracket install help needed!!
Old May 8, 2007 | 08:42 PM
its turbo time's Avatar
Default WOT switch bracket install help needed!!
I have HSW's sudden impact kit and am having a helluva time trying to figure out how to mount the WOT switch, The directions are fuzzy, and was wondering if anyone had any pictures of the bracket installed to give me some ideas.
Search is down BTW!
Old May 8, 2007 | 09:27 PM
Hennytime's Avatar
you have to bend it, like a s bend. sorry i dont have any pics
Old May 8, 2007 | 10:51 PM
Nitro Dave's Nitrous Outlet's Avatar
Getting the adjustable wot bracket to fit can be tricky sometimes. Thats why when I do a install that is not using our digital window switch with built in TPS.
http://www.nitrousoutlet.com/catalog...product_id=964
I use our billit wot switch bracket.
http://www.nitrousoutlet.com/catalog...del=92&dept=11
Dave
Old May 9, 2007 | 02:54 AM
BayAreaSS's Avatar
Dave
I have your window switch and my kit has a WOT switch......I can just use the Window switch and not use the WOT?
Sorry for the
Old May 9, 2007 | 02:58 AM
dementia's Avatar
The one posted is a window/tps switch. TPS = throttle position sensor. TPS replaces the WOT switch. Its basically an electrical/computer version of the WOT switch.
Old May 9, 2007 | 03:02 AM
BayAreaSS's Avatar
Thanks....i just bought the window switch from a friend so i had no idea. I like the idea of using the window instead of the WOT switch
Old May 9, 2007 | 05:30 AM
Danger731's Avatar
you want a wot switch. You can buy a Jimmy Jams wot switch, custom for LS1's.
Harris Speed Works has them
Old May 9, 2007 | 08:50 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
the window switch has a built in TPS activation switch...it taps into the TPS sensor and activates the kit electranically when you go WOT. There is no need for a mechanical WOT switch when using a TPS activation switch.
