Lean Codes After I Spray
Old May 10, 2007 | 07:43 PM
GreatWhiteHype01's Avatar
Question Lean Codes After I Spray
I have a TNT 100 shot on a stock LS1 with Long Tubes, True Duals, No Cats or Mufflers, Cold Air, Stall, Servo, Custom Tune with timing retard for the NOS. I get the 0171 and 0174 Lean Bank 1 & 2 codes shortly after a 2nd & 3rd gear spray at WOT. Is this telling me that I am at full duty cycle on my stock injectors and need a fuel booster pump? Is there any light you guys can shed on this? Thanks.
Old May 10, 2007 | 09:07 PM
Jditlfm's Avatar
Is this wet or dry?
Old May 10, 2007 | 09:21 PM
Question
This is a TNT 100 shot. The fuel is derived from the fuel rails, the nozzles are 39/22 on both. This may sound crazy but TNT swears that these 2 nozzles make up their version of a 100 HP Shot. Thanks. -Tom.
Old May 10, 2007 | 09:25 PM
Talking
It's a wet shot. Sorry about that.
One last thing, I know this is off subject but your pic says you have a 255 Walbro fuel pump. Is this mounted in-line or did you drop the tank and install it? Thanks. -Tom.
Old May 11, 2007 | 06:26 AM
Jditlfm's Avatar
I have the intake fuel pump and i did the trap door method. Your injectors don't play any role in a wet shot so they should be fine. I might look into doing a PSI test on the fuel pump. Get a Fuel gauge like the ones mechanics use, and tape it to the windshield then make a pull in 2nd or third and see if holds PSI under load without spraying. I think you can get a cheap gauge at auto zone with the adapter for around $40.
Old May 11, 2007 | 08:05 AM
Lightbulb
How will I tap in the fuel pressure guage if the N2O is using the fuel rail valve to feed the nitrous nozzles? If the fuel pressure is nose-diving then what can be done at this point? Can you elaborate more on this manifold pump and trap door method? Thanks. -Tom.
Old May 11, 2007 | 08:08 AM
Am I damaging the pistons everytime I get these lean codes? Everytime I make a pass on the spray? Thanks. -Tom.
Old May 11, 2007 | 12:31 PM
LostCauseZ06's Avatar
sounds like you forgot to take the schrader valve out of the fuel rail... your not getting extra fuel with the spray to be setting off a lean code... lean codes only come on if your WAYYYY lean lol
Old May 11, 2007 | 12:42 PM
99Silverado5.3's Avatar
Get a shrader valve puller, one for a tire stem will work, and take it out.
Old May 11, 2007 | 01:08 PM
98Camarod's Avatar
Please tell me that was not the problem....
Old May 11, 2007 | 03:31 PM
I thought about asking the guy but felt like it was a dumb question to ask a Speed Shop Tech. I will be checking to see if it is in there as soon as I get off work. I will let you all know the verdict. Thanks.
Old May 11, 2007 | 03:41 PM
lol 10 bux says he didnt take it out
Old May 11, 2007 | 05:24 PM
Jditlfm's Avatar
Ya ya gotta take that valve out. Its in the instructions if you got any with the kit. Definitely very important. But i would definitely stop spraying until you get it figured out.
Old May 11, 2007 | 06:15 PM
The valve was removed already. We checked it Just to Make Sure. The o2 sensor now gives me the lean bank 1 & 2 even on all motor. I also get the heater circuit malfunction code??? I am thinking about getting the downstream Vetter o2 sensors as a replacement. Will the Bosch brand downstream Vette o2 sensors do the trick? Or the ac/delco ones? Thanks. -Tom.
Old May 12, 2007 | 05:30 PM
98Camarod's Avatar
The Bosch 13111's is what you are referring to. They work on 19 out of 20 cars. I had the 1 out of 20 that it didn't work on.
Old May 12, 2007 | 06:52 PM
Talking
I bought the 13111's and installed them at the track. The lean codes are history! I have not seen the lean bank 1 & 2 codes since then. I have made several passes on the NOS and the motor and no codes yet. I did however get the 1153 & 1133 codes that say "Manufacturer Fuel & Air Metering" I have been getting these codes since I installed the LT Headers and the True Duals. I assume it shoots this code due to the lack of the correct tune for the LT Headers??? Thanks. -Tom.
Old May 13, 2007 | 12:03 AM
gi8e7oi825's Avatar
Yes the 1153 and 1133 codes come up most often with LTs. I had them too until they were disabled.
Old May 20, 2007 | 10:15 PM
Does anyone know where I can get a better Nitrous Tune? I ran 7.53 in the 1/8th on all motor, now I am running 7.35 on the bottle (100HP Wet Shot). I run 7.78 in the 1/8th now on all motor with the timing retard? I am slightly disappointed with the N2O pass. I was expecting a 6.90 pass on the N2O?? Thanks. -Tom.
Old May 21, 2007 | 07:48 AM
98Camarod's Avatar
You're right. You should be in the high 6's very low 7's on the bottle. Where are you located?
Old May 21, 2007 | 04:34 PM
I am located in Mobile, AL. Thanks. -Tom.
