How Big Of A Dry Shot?
Old May 21, 2007 | 09:07 PM
1999ssls1's Avatar
Default How Big Of A Dry Shot?
How big of a dryshot can I run on my car with my fuel system? I have a walbro 255 fuel pump with stock injectors with mods in signature.
Old May 21, 2007 | 09:27 PM
5_02ls1's Avatar
well the 99 has 26# injectors so with that engine im guessing 100-125ish whats the duty cycle on the injectos
Old May 21, 2007 | 10:11 PM
red fury's Avatar
With 26# injectors on a H/C car you have got to be leaning on them hard already. I think if you used some 42# injectors a 100-125shot would be safe with your setup. If your going to drop the $$$ for upgraded injectors I would get some 60#'s and a Casper electronics Voltage booster for your fuel pump since you already running a 100shot wet....your walbro could use the extra juice to help it meet that demand.
Old May 22, 2007 | 02:28 AM
99Silverado5.3's Avatar
Originally Posted by red fury
With 26# injectors on a H/C you have got to be leaning on them hard already. I think if you had some 42# a 100shot would be safe. I would get some 60#'s and a voltage booster since you already run a 100shot wet....your walbro could use the extra push to meet that demand.
You are probably already pushing them pretty hard...definately need bigger injectors to put any decent size dry shot on.
Old May 22, 2007 | 02:29 AM
also +1 on What's the DC is already?
Old May 22, 2007 | 08:36 AM
1999ssls1's Avatar
Im not running the wet shot anymore. Its just going to be a dry shot. Not big either. 150 at most.
Old May 22, 2007 | 07:38 PM
red fury's Avatar
I would go with nothing smaller than 42#' ers......but if your going to have to buy new injectors get some 60#'s cause you never know what future mods you may add to the car, there is no tuning problems with the 60's from what I have heard/read.
Old May 23, 2007 | 06:00 PM
1999ssls1's Avatar
Would the injectors be maxed out with a wet kit?
Old May 30, 2007 | 09:48 AM
1999ssls1's Avatar
Old May 30, 2007 | 10:41 AM
ATVracr's Avatar
Wet shot doesnt use the injectors for the extra fuel.
The dry shot does.
Old May 30, 2007 | 11:22 AM
1999ssls1's Avatar
I was just double checking. Thanks
Old May 30, 2007 | 11:27 AM
1936FordPU's Avatar
You could go up to 200 on the stock injectors if you go boost referenced and drill the nozzle out with that fuel pump..Anymore and Id say upgrade the injectors. This would ask for upgraded rails, boost referenced regulator with a 1:1 spiker.
