timing tuner...again
Old May 25, 2007 | 10:37 AM
MetallicaMatt's Avatar
Default timing tuner...again
hey guys,
before I make permanet connections to everything, I'm confused about something.
I don't understand the white wire, it goes after the 12v switch, and WOT switch, okay no problems
but how will just splicing into that wire that runs from the 12v switch, to the WOT, to the relay do anything??
I mean it'll have juice flowing to it, how will splicing in the white wire cut the juice off??
Old May 25, 2007 | 09:32 PM
anybody??
Old May 26, 2007 | 08:37 PM
nobody? c'mon i wanna get this wired up this weekend
Old May 30, 2007 | 04:56 PM
nobody? what sponsor or manufactur should I give a call?
Old Jun 1, 2007 | 09:36 AM
coolchevy's Avatar
had a similar issue, you need to connect both TT wires, the white and the grey. The TT switches the trigger relais with its own ground. So all your safety switches should be in series to the master switch (master switch, WOT, FPSS, gear selector, whatever) and be connected to the white one as well as pin 85 on your relais, the grey one goes to pin 86 of the relais.
Old Jun 1, 2007 | 10:43 AM
if I'm reading the drawing correctly, I'm just splicing the white wire into that series of safety switches, correct?
I guess I don't see how just tapping into the wire will do anything
Old Jun 1, 2007 | 10:58 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
the white wire is power supply for the timing tuner....to turn the unit on...it will not control the system
The gray wire is the control side....it will add or take away ground to the relay...the timing tuner controls your nitrous system through the gray wire
Old Jun 1, 2007 | 05:41 PM
^^^ okay that makes the connection make sense!
thanks guys, i knew someone knew how it worked!
