Black car + hot weather + full bottle =?
#41
Originally Posted by Lythropus
I heard that not purging your system when you close the bottle leaves pressure on the nitrous noid and that can lead to premature failure...
besides at 1/8 pound per purged 4an line, that means if you use your nitrous 8 times (small 100 shot and you might get 8 runs) you will be able to purge it out every time and only waste 1 pound! That's only 4 bucks where I live and even getting ripped off it's only 7 dollars...You should really not be spraying unless you can afford a built engine if you blow yours let alone 7 bucks...
#42
Originally Posted by FootLbs
I'm curious if anyone has been IN the car when the disk goes pop...
#43
Originally Posted by caliswangin916
i would jump in my car and start inhaling as much as i can so it doesn't all go to waste.
#45
A friend of mine has a red C5 coupe with black interior his was mounted in the hatch and it was a black bottle. On a 90^ day right after a fill he came out to his windows frosted. He still thinks it was just a bad rupture disk.
