Downside to an independent fuel system?
I think it'll make up for it when it reads a little lean on the dyno and all I have to do is up the pressure a few pounds...Or when I can run close to stock timing with c16 in the cell on larger hits...
You might not have to buy those when you stand alone...
think thats about it.
$$$ for a standalone, is cheap insurance if you have tons of money wrapped up in the engine.
Ricky
cost and slight weight penalty are the only downsides imo
id seriously kill myself if i did that... lol
the more complex a system you build the more there is for the chance of something failing. thats how it is with anything.
now if your like me and the stand alone has to be turned on to get power to the nitrous then i see no downfalls, dont run it low, and the only problem id see if initial cost
Thats why i built the KISS kit 1 pump 1 tank 1 reg 1 feed line
What size shot were your running?
