will my rear end handle it?
Old Jun 10, 2007 | 02:14 PM
camarokid239's Avatar
Default will my rear end handle it?
well i own a ls1 98 camaro A4 that has 95000 miles, it has full exhuast,lid,3.73's,(Mt's only on the track), and a trany tune. i was wondering if i should do a 50 shot even though it has 95K miles on it, i dont plan on using it all the time i would just use it for like meesing around on the street, and couple times year when i go to the track.and also i plan on getting a 3200 stall, should i keep the 50 shot or no? im asking cause im real worried about the stock rear end, not sure if it can handle both. plz help
Old Jun 10, 2007 | 02:29 PM
squirts1's Avatar
a 50 shot should be fine, i would be careful with a 100-150shot though...
Old Jun 10, 2007 | 02:43 PM
sidewayz28's Avatar
lol i hope mine lasts with a 100+ its lasted 400+ rwhp for a while now.. i havent launched the **** out of the car yet.. and probably wont for a while
Old Jun 10, 2007 | 03:14 PM
john563's Avatar
I would not worry about a 50 shot,but on a 100 I would worry,but not about the rear,but rather your trans cuz its an A4.
Old Jun 10, 2007 | 06:09 PM
billybadd's Avatar
Get the suspension set up where it wont wheel hop and it'll be ok.
Old Jun 10, 2007 | 11:45 PM
98TA Bandit's Avatar
Like billybadd said wheel hop breaks rear ends my M6 had the same setup lasted about 70 hard 1/8 mile passes and pounding it on the street with a 50 shoot . Your an auto it might last.
Old Jun 11, 2007 | 08:34 AM
02SOMWS6's Avatar
I snapped my axel way back with just bolt on's and slicks. Auto's seem to save the rear so you may get lucky but mine broke NA with minor bolt on's but I was cutting 1.64 60ft's full weight
Old Jun 11, 2007 | 09:23 AM
MrDavid's Avatar
Blah, I have 150shot on a 120K mile engine. I haven't had the first issue yet. I do not launch because I am driving a stock manual rear end with 4.10's . Good friend of mine has 3.73's with a 3500 stall and has had MANY track passes on 10.5" ET's and his rear end has held up perfectly, mine has as well.
Old Jun 11, 2007 | 09:27 AM
xBROKEx's Avatar
its hard to say, i have a friend who's popped 2 rear ends and hes 100% stock and was on street tires
Old Jun 11, 2007 | 06:02 PM
fyrfytnSS's Avatar
doesn't a 1st gear lockout decrease your chance of breaking the rear?
Old Jun 13, 2007 | 08:20 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
See time in sig for my old car. It was on a 150 shot and even had a ring gear spacer. I sprayed mine **** right off the line. Your car will be fine
Old Jun 13, 2007 | 02:02 PM
2camaros6702's Avatar
I have heads & cam with a 125 shot and a 3800 stall and I spray it out of the hole every time with DRs on it and run mid 10s with the stock 10 bolt with 1.5 60's every time. And before the H/C I had a 4000 stall with a 150 shot spraying out of the hole fore about 2 1/2 years running 11.4s. The only thing I had to replace is the tanny. Now I have seen people that only run mid 12s pop the 10 bolt.
