What jets for 150rwhp Dry?
use this calculator. http://www.robietherobot.com/NitrousJetCalculator.htm
Personally, I would still use a jet so it will seat and seal well to the nozzle. Just drill out some 50 or 75 shot jets.
Last edited by BriancWS6; Jun 20, 2007 at 04:15 PM. Reason: Post isnt showing up???
Robert
Would you say if a tune was lean on the gas it would make more power by richening it up? Just trying to see where I am at. I made 110 on .040 jets at 13:1 AFR and did not have time to make adjustments. So what I am saying is if I made more power with 12:1 then I would want to keep that in mind when selecting jets. I do not want to over pill it. I guess I could go with the 48s and run say 900psi just to be safe. I will be sure my fuel is safe with the 40s before I pill it up though since it is lean right now. But I am changing the way the nozzles spray into the intake since I think the MAF is not getting good readings.
Robert
