Nozzle Placement - Custom CAI
Old Jun 20, 2007 | 02:34 PM
crewchef's Avatar
Default Nozzle Placement - Custom CAI
88 GTA w/ LS1 transplant. The CAI is 4" K&N cone filter into a section of 4" SS tube, hump hose joint to MAF then a 90 degree hose into throttle body. MAF is descreened, not ported. Planning on dry kit, not sure which one yet.
Any suggestions on nozzle type and placement?
Old Jun 20, 2007 | 03:34 PM
gi8e7oi825's Avatar
What type of MAF? If it's the one that Corvettes use, I think anywhere a couple of inches before the MAF should be fine. If the f-body version, I'd place it before the IAT sensor. In both cases, I think it's best to spray away from the MAF, but that's only something I read in this forum, meaning I have no personal experience.
Old Jun 20, 2007 | 03:56 PM
Todd157k's Avatar
Unfortunately it would be in the rubber boot area. Going to be tough to adjust. I would suggest about 3" away pointing at the MAF, and then adjust by turning the nozzles away from the MAF. Also, ask the king of dry and see what he thinks.
(robert56)
Old Jun 20, 2007 | 07:09 PM
Robert56's Avatar
I agree with Todd, and furthermore, I would use dual nozzles for more tuning a/f options. You want to start with both nozzles pointing directly at the MAF wire, then you'll get your richest a/f, then if it's a little to fat you can start to rotate one nozzle so as it sprays some or all over the the maf wire. If this isn't enough, then point one of your 90* nozzles directly back into the airstream. You can even go further than this to lean it out, put a smaller jet in the one pointing at the wire and a larger jet in the nozzle going back into the airstream, allthough, I really don't think you will need to go this far.
Robert
Old Jun 21, 2007 | 08:48 AM
crewchef's Avatar
Thanks for the input. I assumed it would end up being in the hump hose which won't be a lot of fun but I'll figure it out. Like the thought of dual nozzles, hadn't considered that.
Another thing I haven't quite figured out; How does the MAF regulate A/F at WOT? I thought at WOT the MAF calculations were ignored and A/F was dependent on PE and VE tables. I see it's working ok for everyone just want to understand how/why. I have HPTuners so I'll be able to start small and log the runs to see what's going on.
Old Jun 21, 2007 | 09:25 AM
Beer99C5's Avatar
Actually I believe above 4000 RPM (Stock Tune) it pretty much goes by the MAF.
I have EFI Live and the tables are not idenified the same in HPT (WHICH REALLY SUCKS for end users like us with different tuning packages)...
Look at the HPT equivelent of RPM Threshold for Airflow Calculation
If engine speed is above this value, then the PCM will use the MAF sensor exclusively (if not disabled by DTCs) to calculate grams of air per cylinder.
Stock has it at 4000 RPM
Old Jun 21, 2007 | 04:35 PM
crewchef's Avatar
Thanks Beer, I sometimes get things backward like that. After I thought back on it and looked at how I was tuning you're absolutely right. I tune the VE tables by driving around under 4K and staying out of PE mode w/ MAF disabled. Don't worry about anything over 4K becaue it's all MAF from there on. I would do ok on this stuff if I could get out of my own way
Old Jun 21, 2007 | 04:45 PM
1999ssls1's Avatar
If you dont mind me asking, how much spray if you go dry shot?
Old Jun 21, 2007 | 06:22 PM
Beer99C5's Avatar
Injectors seem to be the limiting factor in Dry. Stock 28's generally 100-125 shot.
My Stock 26's I was limited to a 50 shot. I intend to go 150 with my 42's (and should be able to go higher).
Old Jun 21, 2007 | 06:34 PM
crewchef's Avatar
Maybe someone I know? We'll start out small and see where it goes from there?
Old Jun 21, 2007 | 08:40 PM
Robert56's Avatar
One thing to consider when tuning, if your LTFT's are postive they will freeze at WOT and be added to your PE, if they are negative they will be dropped at WOT. So this is why most want slightly neg LTFT's, they won't effect wot a/f as commanded by PE multiplier. Another area to attend to is what rpm you have your PE set to activate, put it a little lower RPM wise from your N2O on rpm, this way you have enrichment right away when spraying (a trick to help stop the nasty lean spikes).
Robert
Old Jun 22, 2007 | 12:23 AM
1999ssls1's Avatar
I was asking because of injector size. I dont believe I know you. If you will read my post I have been trying to figure out why I am wondering about the dry shot.
Old Jun 22, 2007 | 08:05 AM
Robert56's Avatar
Check out the wet vs dry thread, somewhere I posted the math for injector sizing per HP sought concerning a dry hit and fueling. If ya can't find it, let me know.
Robert
