**PICS** Nitro Daves 85mm plate, stand alone, and more...
Here is the new set-up. It's a NX wet kit, purge, NX nitrous filter, FPSS, custom 85mm plate from Dave, NX auto heater, Nitro Daves stand alone fuel system, FJO progressive controller, and a Nitro Daves back seat bottle mount. It went in the car this last month along with a Rossler built T-braked RMVB TH400, ATI 8" 4000 stall treemaster converter, and a B&M Pro Ratchet shift kit. Dave made up my 85mm plate to accomidate my Professional Products 85mm intake, and Professional Products 85mm throttle body. With a 100 shot, the car put down 442rwhp through the TH400 and a Moser 12 bolt with 3.90 gears. Other than the juice, I'm running a small cam(.566 lift) and bolt-ons. Stock guts and heads. Thanks again Dave for all the help!! Here are a few pics. Enjoy!
Originally Posted by 98SS1LWEE
Ooh, where can i get a plate like that? I have the PP 86MM Intake as well, would love to see one of those plates fitting on mine too
Originally Posted by IH8FORD
Love that switch panel, I was already getting ready to buy that fuel cell. Are you all ready home from Iraq. I won't be until the 21 of July.
02SS, Any problems with your N20 setup after you went with the Typhoon? I cant make any power with mine, only gaining about 30 rwhp with pills for a 100-shot. It worked fine before the manifold swap, now I just get a pig-rich AF condition, but no bog. Also running Nitrous Outlet's 85mm plate.
was that manifold worth the money? I think yours is the first i've seen not in a catalog....i want to go LSX but Pro. products lays claim to a decent HP gain but its aluminum...any heak soak issues?
Heatsoak......bottom line, the thing gets hot enough to burn your hand, just like any other aluminum intake. I don't think its an issue though. Not enough to notice anyway.
so far i'm happy, caused some idle issues with my cam, and about to cause more cause i'm going with a t-rex cam. bt definitley wanting one of the matching throttle bodies now offered
02SS, what jets are you running in your plate?
01Black, check out my before/after dyno reports on the Typhoon in the Gen III engine forum, if you are looking for gains this thing will not produce.
I will be hoenst, i don't care, it's gorgeous. I love mine, and yes, it's hot as crap, but who cares, if i'm on the move, my hood takes me down below thermostat, and if i'm at the track, ice all over the place!!! It's jsut purty, and purty cheap
