nitrous with stock gears and stall
Old Jul 3, 2007 | 08:07 PM
Black99TransAm's Avatar
Default nitrous with stock gears and stall
hey everyone, im getting the bottle installed this weekend. im planning on a 100 shot with the nitrous express kit. the car is a 2001 z 28 with 61000 miles. the trans is stock(Auto), it has stock gears, (2.73s) and the car just has bolt ons. (Headers, y, catback, lid/smoothbellows, ported maf) i have a window switch, fuel pressure safety switch, plugs and of course the complete kit. im also installing a blow down tube, bottle warmer, and a purge. im just wondering how well the nitrous will do with the stock gears,stall. trans and what all you all would recomend if i forgot anything... and what to do after first time spraying it to make sure its running good a/f ratio.
thanks
Old Jul 3, 2007 | 09:13 PM
Hennytime's Avatar
i did it, and id recommend hitting it on the dyno and dialing in your a/f. thats key. then take it to the track and make an n/a pass and a nitrous pass. with your drivetrain you should pick up about 8 tenths and 8-10mph if running right
Old Jul 3, 2007 | 11:07 PM
bonestockz06's Avatar
Your stock drivetrain will hold up just fine with 100 shot once A/F mixture is dialed in. Goodluck and enjoy your added power.
