Timing for a 150 shot
Old Jul 6, 2007 | 09:41 AM
RZRSEDGE's Avatar
Default Timing for a 150 shot
I have HP tuners and would like to tune the timing myself. I know that I need to pull between 4.5*-6.0* of timing out but my ? is, where so I pull it from? Only the max timing or all across the board? This is on a wet kit fwiw. Thanks for looking!
Old Jul 6, 2007 | 09:49 AM
slow trap's Avatar
i ran a 150 shot without pulling any timing but now i pull 4 degrees using a timing tuner. i have a standalone now so i will probably put in 100 or 104 and may not pull any timing out.
Old Jul 6, 2007 | 10:01 AM
RZRSEDGE's Avatar
Thanks. When you pulled the 4 degrees, was it across the whole timing curve or just at peak timing?
Old Jul 6, 2007 | 11:57 AM
2002_Z28_Six_Speed's Avatar
One would think .75 grams/sec and more. 3000 rpm and more. That area of the spark map.
Old Jul 6, 2007 | 12:02 PM
RZRSEDGE's Avatar
That's exactly what I needed to know! Thanks! I'm new to the tuning game and was not wanting to play Russian roulette with my motor right now. What would be the suggested amount, 4.5 or 6.0 or anywhere in between? Another question is can I put the nitrous tune in and out at the track so I can run optimum both NA and on spray?
Old Jul 6, 2007 | 12:35 PM
oange ss's Avatar
start with 4 degrees, may have to start pullin timimg out earlier than .75 gm/s depending on when you spray and the vehicle....
Old Jul 7, 2007 | 04:10 PM
01_ram-air's Avatar
I bumped UP the timing--25* across the board. I do add a little 100 octane at the track though.
Old Jul 8, 2007 | 11:57 AM
RZRSEDGE's Avatar
Thanks for the advice everyone!
Old Jul 8, 2007 | 01:03 PM
mrr23's Avatar
i run stock timing tables with a 150 shot.
Old Jul 9, 2007 | 04:59 PM
SPDEMON's Avatar
-4 degrees here. Safe is best unless you are rich.
Old Jul 11, 2007 | 01:42 PM
Zero4488's Avatar
Restricted User
I have the diablo sport tune on my car....I have a 150 shot setup...should I remove the the diablo tune before I spray it. Mind you, I haven't sprayed yet and am just trying to work out all the bugs in my system....
Old Jul 11, 2007 | 01:47 PM
brad8266's Avatar
stock timing, **** I still run stock timing on H/C/150 shot
Old Jul 11, 2007 | 04:01 PM
oange ss's Avatar
depends on the extra timing if any the canned tune added...
Old Jul 11, 2007 | 05:17 PM
Zero4488's Avatar
Restricted User
alrighty....so I should ex the diablo tune when it's time for spray?
Old Jul 12, 2007 | 06:00 PM
brad8266's Avatar
I would, those handhelds add timing, you dont want that.
