150 wet??????
Old Jul 13, 2007 | 07:18 PM
Twinki025's Avatar
Default 150 wet??????
Alrighty guys who is spraying 150 wet with the stock fuel pump with just bolt ons only. No h/c just basic bolt ons. I did 125 shot this weekend at the track i ran 12.1 @ 119. I vaporized the tires in first. My 60ft was 2.10 Now i have the 150 jet and im itching for 11s. Let me know whos doing and how its working out for you....
Old Jul 13, 2007 | 07:32 PM
mrr23's Avatar
been doing it for a couple of years. made 481 rwhp and ran 11.397 @ 120.96 in the wife's car. stock fuel pump, stock injectors, stock lines, all stock fuel system.
Old Jul 14, 2007 | 01:46 AM
transamfreak01's Avatar
man get a tire on that car.... get that 60ft down and ull be 11's easy with the 125
Old Jul 14, 2007 | 12:34 PM
white mongoose's Avatar
like transamfreak said get some tires 1st so u could drop ur 60 and u dont even have 2 use the 150 shot stick with the 125, just get some tires and get it 2 hook and ull be in the 11 with no problems are u m6 or a4
Old Jul 14, 2007 | 01:44 PM
123sugey's Avatar
EXACTLY !! Get the car to hook first..........
Old Jul 14, 2007 | 01:57 PM
Twinki025's Avatar
im auto 3000 vigi stall. I i have nitto drag radials on it and i still cant get it to hook. And the stall is loose as hell to . 3.23 gear stock rear end.
Old Jul 14, 2007 | 02:15 PM
its turbo time's Avatar
Whats your tire pressure? Do you still have your front sway bar?
Old Jul 14, 2007 | 03:12 PM
ditch the nittos. get some mickey tompson et street radials. you shouldnt have a problem hooking. nittos in my opinion suck
Old Jul 14, 2007 | 03:43 PM
brad8266's Avatar
^^ yeah nittos suck. Anyway most 150 shot kits are designed to be used with the stock fuel system and stock timing. Having the aftermarket pump is just good insurance.
Old Jul 14, 2007 | 05:07 PM
i thought when runnign a wet shot your pump should be changed????? and when you do a dry its recommended to do injectors.
Old Jul 14, 2007 | 05:12 PM
Twinki025's Avatar
Yes i still have the front sway bar. What exacly does the taking off the sway bar do?? I was running 22 psi in the tires
Old Jul 14, 2007 | 05:26 PM
dont take the sway bar off
Old Jul 15, 2007 | 08:17 AM
01_ram-air's Avatar
There's nothing wrong with taking the front sway bar off. I've driven around for over 2 years without mine on. And now, I drive with skinny's on the front.
removing the front sway bar does two things:
1) takes weight off the front
2) helps with weight transfer to the rear tires.
Bolt-ons, 4000 stall, 150 shot
Best so far is 11.07 @ 121, 1.56 60'
Old Jul 15, 2007 | 12:20 PM
If you are serious about getting your car to hook, i would consider ditching your swaybar, and maybe try 18 psi in those tires before you just completely throw them out. Also do like a 10 sec burnout while staging. If you still can't get it to hook try some MT DR's.
Old Jul 16, 2007 | 03:58 PM
greyghost4x4's Avatar
Banging some gears
i ran my nitto DR's on 12psi at the track! hooked like a beast!
