URGENT!!: FJO help.... not firing solenoids.
IF the lights are staying on all the time you may have fried the box. we fried 1 also. FI you use the fjo to ground the noid it cannot take the load and it fried one. you have to use the fjo to ground the relay wich sends power to the noid. the noid should have an good chasis ground. I learned this the hard way on one of my first kit installs with an fjo.
