Help!!!!
So I got a nitro daves plate kit with purge, fpss, and the nitro daves window switch. Well I wired some thing on the relay wrong and everything is fixed and wired ok now. Well the window switch has a two stage set up... i programmed the stage one which I am hooked up to and the stage two is just all set at 000 and unwired. Well when i flip the arming switch fuel just dumps out of the noid(dont know what the nitrous is doing...bottle not hooked up). So i program stage two in the window to match stage one and it stopped dumping out the fuel....Is there any way to test and make sure everything is working right? I really dont wanna blow up my motor. Could there be somethin up with the window switch or maybe the noids?? Any help would be great!!!!
Thanks
Be careful, if the nirous noid is activationg with the fuel noid (it should if wired right), you may burn the coil out on the nitrous noid (it relies on the nitrous for cooling).
Check your relay wiring. Also your WOT function (or mechanical WOT switch if your running one).
As Dean said tape up the second stage wire (do not cut it, you will hurt the resale value of the window switch if you go to sell the kit).
