Wanting to clean up engine bay....solenoid placement suggestions needed.
Originally Posted by BobDoLe
i've had no problems at all. just keep in mind that the noid is going to want to jump when it opens. i have the zip tie holding onto the noid when the fitting meets the noid, then it attaches to that ac line directly underneath it. the steel braided lines help to keep it from sliding up the ac line.
1 Post
I used the brackets that Dave sells in frame #13. I really liked that setup. My controller was next to the factory ground post next to the battery. That old setup was a good one for sure.
