Msd digital window switch
Old Jul 31, 2007 | 07:56 PM
Black99TransAm's Avatar
Default Msd digital window switch
I am installing a msd digital window switch on my camaro with a nx kit. I know where 3 of the 5 wires hook up to. I know where Black goes- Ground. Red- Switch 12volt. White- Tach signal on ecu.
There are 2 wires where i dont know where to wire them into.
Grey- Normally closed switch output.
Yellow Normally open switch output
So where do the yellow and grey wire into on the nitrous kit.
thanks
Nate
Old Jul 31, 2007 | 10:58 PM
01'WS6's Avatar
thanks
Nate
Grey you dont use and yellow to your FPSS or if u dont have one then to prong number 85 on your relay.
Old Aug 1, 2007 | 07:23 AM
GDM Z28's Avatar
care to post up a diagram? im a little confused on this one. so the wire that goes to the 85 prong on the relay is what activates the kit once it reached the programed rpm?
Old Aug 1, 2007 | 07:52 AM
striker754's Avatar
Im not familiar with the msd switch, but does the yellow wire switch to ground during the rpm window? and if it can handle the current of relay coils, hook it up inline with your fpss, wot switch, etc which should all be connected to the ground of your relay coils (pin 85 or 86 on the relay)
Old Aug 1, 2007 | 09:13 AM
ICRAZY6's Avatar
Here you go: http://www.msdignition.com/pdf/FRM23778-PN%208950.pdf
Old Aug 1, 2007 | 04:44 PM
Nitro Dave's Nitrous Outlet's Avatar
Old Aug 2, 2007 | 07:37 AM
GDM Z28's Avatar
dave which wire on the ecu should i tap for the tach signal? or should i get it off one of the wires on the coil connector on one side of the motor?
Old Aug 2, 2007 | 08:40 AM
rpmauto's Avatar
I just had a question on the digital window switch, I just hooked mine up last week, works wonderful. I was reading a post on here that had said that u have to have the cyl set to four to read right. as it turns out this is true, my question, why? the instructions say one cyl. if you are tapped into the tach output wire by that time the analog signals from the cam or crank sensor, witchever the ecm uses to referece injector pulse and spark should have been filtered to a digital signal the ecm can read. Of course i have not done a ton of research on how the gen 3 system reads. just seems strange to me, but if it works, who cares.
Old Aug 2, 2007 | 09:32 AM
Chris@NitroDaves
Guest
Posts: n/a
light Green wire with White tracer or it's just solid light Green
Old Aug 2, 2007 | 10:09 AM
GDM Z28's Avatar
chris also im not looking at my car right now and since you do a lot of wiring you might be able to answer this so i dont have to leave the a/c office
if you dont run a FPSS you just run the wire from the msd box to pin slot 85...but what if you dont run a FPSS or the window switch? what do you do with slot 85?
Old Aug 2, 2007 | 11:13 AM
striker754's Avatar
ground it
Old Aug 4, 2007 | 01:29 PM
deadlift's Avatar
thanks for the pic dave
