single stage wet kit problem
Old Aug 3, 2007 | 12:07 PM
nofxrxmxpx's Avatar
Default single stage wet kit problem
I cant get the kit to spray... here is the wiring diagram i followed..
http://i73.imagethrust.com/images/1V...h-a-relay.html
my main concern is that i used one ring terminal for the orange and black wires on the mallory box and terminated them to ground together, could this be the issue?? what should i be looking for?
Old Aug 3, 2007 | 12:53 PM
Todd157k's Avatar
Read my post on page 2 of this sticky
https://ls1tech.com/forums/showthrea...=649117&page=2
it will tell you have to trouble shoot the system to see which part is not working. And No, grounding those two together is not the problem. The only time grounding together is a problem is when it is a sensitive device such as the grounding for a wideband. Those grounds you keep away from other grounds.
Old Aug 3, 2007 | 02:28 PM
nofxrxmxpx's Avatar
ok i fixed it....
heres another question... with the fuel line off of the nozzle, when sprayed(into a sealed bottle for safty) how much fuel is supposed to come out.. its a small noid 150shot max... sorry for all the newb questions i just need to make sure this **** is going right before i put my big *** 75 shot though her
Old Aug 3, 2007 | 03:34 PM
Todd157k's Avatar
Here. It's simple to figure out...
j/k. If there's fuel flowing out, it's working. Just make sure you have the correct size jets and watch the AFR.
