Can I spray???
I was wondering if i could spray a small shot before i get a tune? My timing is at 28 degrees so i doubt i can spray but i just wanted to double check. I was thinking a 50-75 shot.
What do you think?
I just want to know if my timing is to high to spray a very small shot.
if you can switch it back to stock timing, running a 50-75 shot shouldn't be a problem (but keep in mind you'll get knock even with stock timing and no nitrous since we're stuck with 91 octane).
I see you got the itch eh? haha did you get your tr6's in yet? i think your timming is a lil too high for spray
i used hptuners to back the timing off a bit when the nitrous (dry shot) hits.
But what size shot are you running?
And did you take out timing from 2K-4K RPM on the stock tune because you got knock?
