Nitrous noob
Old Aug 23, 2007 | 11:14 PM
Raceon3's Avatar
Default Nitrous noob
How bad is nitrous for your engine? If I put a 100 shot on a pretty much stock C6 is it going to hurt anything?
Whats the biggest you should run on a stock LSX engine?
Thanks for your help
P.S. I tried a search but it was down.
Old Aug 23, 2007 | 11:57 PM
transamfreak01's Avatar
100 is going to do nothing on your car.. you can run 150 shot with no problems. i say run 150 wet shot but with the kit get a heater, fpss, plugs, blow down tube window switch, and a new fuel pump. before all of that though i would do your basic bolts on and you will get more out of the kit. read the stickies though
Old Aug 24, 2007 | 12:01 AM
Empatho's Avatar
+2 on the boltons
100hp is nothing for your ls2
Old Aug 24, 2007 | 12:06 AM
Raceon3's Avatar
Sorry....I said stock but I have full exhaust, CAI, and a dyno tune.
Is the install easy or should it be done by a somebody that has done it before? I'm a mechanic by trade so I know my way around an engine bay....I'm just a nitrous noob.lol
when you say is going to do "nothing" do you mean I wont get good power from it or it wont hurt my LS2? I'm guessing you mean it wont hurt it but I'm just making sure. lol
And what is a reasonable price for the 100 shot kit and all the goodies + the install? Thanks for the help guys
Ryan
Old Aug 24, 2007 | 12:13 AM
Empatho's Avatar
it wont hurt the engine, since you have a tune you are going to have to pull some timing, are you going with a wet or dry kit? I would go with a dry kit if you are only going to use 100hp, if you want to save money do the install yourself its really easy and then get a nitrous tune and some colder plugs woulndt hurt either
Old Aug 24, 2007 | 12:27 AM
Raceon3's Avatar
I dont plan on using the nitrous all that much...maybe a few 1/4 miles passes and a few street races a year. How much Hp will I lose with a nitrous tune if I run on all engine?
I'm not quite sure if I'm going to get a wet or dry kit. I'm going to spend the next few weeks researching to make sure I get what I really want.
Will the stock tune work with a 100 shot or do I do I need to pull the timing down more than stock?
Ryan
Old Aug 24, 2007 | 12:35 AM
Jogar80's Avatar
I have a C6 with all the bolt-ons plus heads/cam. I'm currently running a TNT 150 shot on it. No problems whatsoever, and the kick in the *** is just insane. Wet kits are a little more expensive, but easy to tune, and most any tuner can do the tuning. Dry kits are a lot cheaper, and are very safe as well. You could probably install either kit yourself, but you'd need some tuning. You can probably do a 75 dry shot without any tuning. Go for it you are going to love it.
Old Aug 24, 2007 | 12:43 AM
Empatho's Avatar
since you have a tune already I would pull some timing just to be safe, you wont loose that many HP
Old Aug 24, 2007 | 06:17 PM
Raceon3's Avatar
What H/C combo are ya runnin bro? Thats going to be my christmas present
Old Aug 24, 2007 | 07:03 PM
SPRAYED 01's Avatar
https://ls1tech.com/forums/lsx-parts-sale/767453-complete-tnt-kit-harris-standalone-h-c-injectors-exhaust-chicago.html
I have my entire tnt kit for sale if you want to save a little money on a really nice kit.
Good luck.
Old Aug 25, 2007 | 12:16 AM
Jogar80's Avatar
It's a very mild cam, lingenfelter GT16 cam: 224/228 114 lsa, with some stock ported heads, and all the supporting mods. 452 hp to the wheels on motor.
