Who else has had a nitrous backfire?
Old Aug 30, 2007 | 07:26 AM
Matt@HSW's Avatar
The K came in BTW.
Matt
Originally Posted by TNTramair
Thanx Noyz...it did suck, nothing more depressing than seein all that hard work and money up in smoke but, it happens and is apart of the game. i was unsure on what i was doin with it for awile but i made my mind up and im bringin it back to life soon....went Forced induction this time, just waiting on a few parts so i can start putting it back together.
Old Aug 30, 2007 | 07:51 AM
ATVracr's Avatar
It didnt hurt my intake just blew the gasket out from between the top and bottom.
Killed the MAF and the lid though.
Dynoed it last night the motor is fine and the speed density tune went smooth BUT ...
I borrowed a 275amp alternator from someone and from what I hear now they dont like high RPM's well I'm shifting at 7400 rpms so needless to say it killed it.
We tried my old alternator with the main power feed to the Direct port wired right to the battery. Well it didnt work turned on the DP only and the voltage dropped to 8-9 right away.
This is REALLY starting to **** me off!
Its going to roll out once we get this gremlin figured out
Anyone know of a high output alternator that can take some RPM.
Old Aug 30, 2007 | 08:02 AM
kp's Avatar
kp
I have a 145 amp alternator someone did local thats fine to 7300rpm.
If you are having voltage issues stick a voltblaster on there, at WOT it ups the voltage to 15-16 volts. Helps keep the ignition and fuel pumps going. Been running the 145 amp plus the voltblaster for a year with no problems. My car had a crapload of voltage drop when everything is running and after two or three passes with the stock alternator the car was at 10 volts WOT, sucks when the car is drawing more then the stock alternator puts out.
Old Aug 30, 2007 | 08:48 AM
ATVracr's Avatar
Thanks a bunch KP!
What voltblaster are you using?
Old Aug 30, 2007 | 08:55 AM
Nitro Dave's Nitrous Outlet's Avatar
Originally Posted by Robert56
****, I had to open my mouth. I had one tonight at WOT above 6000rpm, boom. MAF is missing a resistor, the stock bellows split and air cleaner is toast. The issue was it went WOT and stayed there, even after the boom, i had to shut the key off to bring the rpms down. Now, with or with the MAF it goes wot at the rpms sky rocket. I am sure glad it was dry hit, and prob some sort of lean backfire, not really sure exactly what happened, but my big $$ motor seems fine.
Robert
Robert,
Told you back fires happen with dry nitrous systems as well. Its just that wet systems are usualy for violant do to the added fuel vapors in the intake.
However wet or dry if the system or tune up is not right backfires can happen.
Glad everything checked out ok.
Dave
Old Aug 30, 2007 | 09:00 AM
DanielZ06's Avatar
So what can ultimately prevent nitrous backfires? Regularly checking the plugs (after how many bottles)? Not hitting the rev limiter or spraying off the line?
This has got me a little jumpy.
Old Aug 30, 2007 | 09:33 AM
Correct tune up, Window switch and the car being machanicaly correct will normaly prevent nitrous back fires.
Dave
Old Aug 30, 2007 | 11:11 AM
kp's Avatar
kp
Originally Posted by ATVracr
Thanks a bunch KP!
The one from casper electronics, speed inc sells them too. Costs 80.00 and takes 5 minutes to install, helped me out a bunch especially since the BS3 does not like low voltage at high rpm.
Old Aug 30, 2007 | 12:10 PM
ATVracr's Avatar
I see it.
Thanks again
Old Aug 30, 2007 | 09:33 PM
Robert56's Avatar
Originally Posted by Nitro Dave's Nitrous Outlet
Robert,
Dave
Yea, I allways agreed, except to say very rare, and yea I am sure glad I didn't have the fuel vapors in the intake or it may have been like TnT's. the problem I have been having is surging rpms, and this time it went to the moon. Backfired and kept on running. Man it was so lowd my buddies in the pits heard it and said ****. I haven't even looked at the logs yet, not totally sure what's up. But I am going to have Ellis help out I think. We had some surging the other day and found some issues, we thought, but something is still up. I guess if it was easy pushing the envelope everyone would be doing it. This was a 260rwhp shot.
Robert
Old Aug 30, 2007 | 09:38 PM
Robert56's Avatar
Dave
One of my WS may have went on the blink and let it spray past cut off rpm. I speculate this cause I have been having problems shifting cause of what appears to be tach lag, currently shifting at 6000rpm and it still hits the limiter at 7000rpm. So if WS is acting up, and the combo of hitting the limiter, and then the pcm killing the fuel, and still spraying the big half, well a recipe for a high rpm lean backfire. Damn this gets expensive, hehehe.
Robert
Old Aug 31, 2007 | 02:04 AM
  #32
Empatho's Avatar
thats why Im going with a dry kit, becasue If I get a backfire chances are that it wont be that bad.
Old Aug 31, 2007 | 09:27 AM
  #33
ATVracr's Avatar
**** this car !!!
Tried the voltage booster and Shiz's 160amp truck alternator and it helped but not enough.
I guess we are going to try switching from a 4 noid set up to a 2 noid.
Or I'm going to put a motor converter in it, take the DP off and drive it around.
Talk about frustrating! I may not be bringing the car to Memphis.
Old Aug 31, 2007 | 09:36 AM
  #34
Fireball's Avatar
are you sure its not a bad noid...have you tried putting two batteries in parallel (to keep them at 12 volts) to see if the extra capacity prevents the drop? maybe up to a larger gauge wire to prevent voltage drop?
Old Aug 31, 2007 | 09:39 AM
  #35
SMITH's Avatar
you sound like me.
Old Aug 31, 2007 | 10:10 AM
  #36
ATVracr's Avatar
I'm not sure but they are brand new.
When we tested the kit (off the car to check the spray pattern) they worked fine and that was off a 1/2 dead jump box.
**** doesnt make sense Steve is firing 4 noids with no problems and everything I have is an upgrade from what he is running (alternator, battery, feed wire)
Old Aug 31, 2007 | 10:11 AM
  #37
ATVracr's Avatar
Originally Posted by SMITH
you sound like me.
I'm ready to go back to racing 4wheelers! whats a few broken bones
Old Aug 31, 2007 | 10:41 AM
  #38
oner's Avatar
Default wasn't the nitrous' fault...I'm dumb.
I had just installed a zex kit in my 98A4 jetted for a 75 shot. Now, at this time I had never used nitrous before so I was very nervous. To make a long story short, I did my burnout in first, activated the arming switch, staged and took off. I all ways race in 3rd NEVER manually and I was so nervous that I left the bitch in first after my burnout and never put it in 3rd. The car hit the rev limiter hard, backfired and turned off. Nothing blew up but my lid broke.
Old Aug 31, 2007 | 12:47 PM
  #39
Empatho's Avatar
good thing nothing broke but the lid, is it dry or wet?
Old Aug 31, 2007 | 08:10 PM
  #40
Robert56's Avatar
Check all your grounds and/or make jumpers directly to batt for testing. Sounds like maybe a bad connection which is acting like a resistor. I know grounds on our cars can cause all sorts of issues. I see ya stated you have a new batt? That was the reason mine was dropping voltage (bad cell), and mine works fine with stock alt with dual heaters running, both fans, lights and dual to quad noids? Hope ya get it sorted soon.
Robert
