Why not this instead of LM-1???
Old Sep 3, 2007 | 12:44 PM
Ms Eliz's Avatar
Question Why not this instead of LM-1???
I am looking into buying an AF meter and I am leaning to the FAST™ DUAL SENSOR AIR/FUEL METER. Any reason I should not go this route?
http://www.fuelairspark.com/Product.../meter/over.asp
My primary use is for tuning my nitrous wet system on an 03 LS6. I do not have a tuning package such as EFILive or HP Tuners. My ride has been Dyno Tuned. I simply want to see my AFR's and be able to monitor and look at logging through out the RPM range NA and when spraying the N2O.
I look forward to your expert opinions as always!
Ms Eliz
Old Sep 3, 2007 | 02:58 PM
Robert56's Avatar
I am sure the FAST is fine, but know not much about it. The LM1 is a great tunner tool. You can input rpm, fuel pressure, nitrous pressure and/or what ever you want and graph it with their software. SO much this unit can do, check out the dedicated Innovative forum and you'll see why this is a great tuning tool.
Robert
Old Sep 4, 2007 | 06:10 AM
Ms Eliz's Avatar
Thanks Robert!
I'm not sure what all input can be used on the FAST Meter. I thought I'd call them and see. Apparently, the FAST does not come with graphing software. This is another check mark in the LM-1 column...
I'd like some more opinions too!
Ms Eliz
Old Sep 4, 2007 | 07:10 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
I would agree with Robert on this one. The fast is a decent unit but why not go for the best. Here is some more info for you:
We carry the complete Innovate line let us know if we can help you.
Dean
Old Sep 4, 2007 | 06:23 PM
Ms Eliz's Avatar
Thanks Dean...That is some really great info!
Ms Eliz
Old Sep 5, 2007 | 01:08 PM
Black2001z06's Avatar
Robert
The FAST WB has an output to data log/interface with HP Tuners.
Me personally, I plan on data logging everything via the MPVI Pro black box.
The FAST WB also has data logging capabilities integrated as well.
Old Sep 5, 2007 | 01:27 PM
Beer99C5's Avatar
I have the LC-1, it was a bitch to get going but its been running great for over a year (Dean and Dan @ Dynotune gave me great customer service wit, and matches the Dyno wideband's I have been on by .2
I am going with a LM-1 (way easier to wire up than a LC-1) next when I get around to tuning my 04 Avalanche and 73 Mopar because it is easily removable.
Old Sep 5, 2007 | 07:39 PM
Robert56's Avatar
The LM1 can also be logged into your HP Tuners program, or logged onto any laptop with out a tuner program, or logged directly into the lm1. You can put the lm1 in the glove box and remote mount a gauge. Here's the optional windshield mount (pic below), which I like cause i can push the log button anytime without having the laptop hooked up, and also see the a/f. Then later you can down load and analize with the innovate software, along with upto, IIRC, seven other parameters. Or you can log and watch real time logging on your laptop and leave the LM1 hidden. It's really a full tuning tool, not just a WB data logger.
and a first mount I made to hook onto a/c grill,
a better pic of windshield mount,
Robert
