New bad boy intake!!!
Old Sep 13, 2007 | 12:33 AM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Originally Posted by Beaflag VonRathburg
Cary at ET heads.
I'd like to see the heads flowed. Then bolt the intake down and flowed again on the same bench. It would be nice to see what it does. It would be really nice to test it with an elbow, but I know Tuff's running a top mounted tb. Is it a 4150 or 4500 flange?
The runner area on this intake looks humongous compared to the vic jr and gmpp. Even ported I don't think either would compare. I can't wait to see results out of it.
We will be testing this friday and sat so i will for sure post back my results and thoughts,give me till sunday for what i think.
Old Sep 13, 2007 | 04:38 AM
JL ws-6's Avatar
Race your car!
you could not run an elbow on that intake, the intake itself it way too tall, there's no way anyone makes a hod that high, nevermind trying to see over it if someone even did.
Old Sep 13, 2007 | 03:06 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Sounds good.
I don't know. He said it's an inch and a half taller than the GMPP which is lower than the vic jr. I've seen people fit a vic jr with a pretty large elbow on there. The key is will it fit an elbow that flows well enough not to choke it?
Old Sep 13, 2007 | 04:00 PM
ONEBADWS6's Avatar
I run the Vic jr with a elbo and a spacer. It is mildly ported and I flowed it with the elbo and TB attached to the head. Down low I lost nothing by .650 I lost 45cfm
Old Sep 14, 2007 | 10:28 PM
ls1408cp's Avatar
wow that sucks. I had a ported victor jr and it worked well but I am going to try a Beck sheetmetal. Nice to see ETP stepping up
Old Sep 15, 2007 | 01:24 AM
ApexVIII's Avatar
sick!! how where did you get that made? custom?
Old Sep 17, 2007 | 12:07 PM
ONEBADWS6's Avatar
It's worse with a ported Fast and a LS6.
Old Sep 17, 2007 | 10:12 PM
OWN3D BY MY PROF!
And...
Old Sep 18, 2007 | 07:20 PM
tuff's Avatar
Are head gaskets were pushing water like no tomarrow.We have to change the gaskets and try in a couple weeks.
Old Sep 18, 2007 | 08:08 PM
OWN3D BY MY PROF!
Doh... Well, I'll look forward to an update then.
Old Sep 19, 2007 | 08:07 AM
ShiznityZ28's Avatar
I thought you had that fixed
Old Sep 19, 2007 | 05:52 PM
  #32
tuff's Avatar
The head gaskets did not even come close to taking the second time around.We tryed going rounds in are class hoping to limp it through the night so i wouldn't lose to many points.The end result was two burnt pistons from lack of water in block.We were two cylinders down on the last pass and still mph 148. We will be out in two weeks all parts are ordered and went with a diffrent gasket company so hope it holds together for the rest of the season.LSX will be in the works shortly.
Old Sep 19, 2007 | 06:54 PM
  #33
OWN3D BY MY PROF!
Damn, you nuked another 408. I guess if you've got money to burn..... At least you should go faster with more cubes.
Old Sep 19, 2007 | 08:41 PM
  #34
tuff's Avatar
We lifted a ring not distroy with a rod failure big diffrence.Couple slugs and and we will be back in action.
Old Sep 19, 2007 | 08:50 PM
  #35
OWN3D BY MY PROF!
That's good. When you said, "two burnt pistons" I thought you meant you melted them and scored the cylinder walls.
That's not that bad then if it's only going to take a couple new pistons. Still sucks though, good luck.
Old Oct 1, 2007 | 06:19 PM
  #36
stevemilz's Avatar
I need that intake!!!!
X2!!!!!!!!!!!!!!!!!
Old Oct 1, 2007 | 08:33 PM
  #37
OWN3D BY MY PROF!
Originally Posted by stevemilz
X2!!!!!!!!!!!!!!!!!
X3
Happen to have any news for us?
Old Oct 1, 2007 | 08:50 PM
  #38
tuff's Avatar
Sorry guys i will not be able to get it back together,Parts are to far out and weather is going to get pretty crappy by the time i get my stuff.We burt two pistons due to the tuneup being to lean.This motor wants fuel compare to the old intake and cam.I made a bad call on the tune not knowing that the combo made that much of a change.Motor was tuned N/A but my nitrous setups i was use to was to lean.We melted down at about the 1000ft mark and still went 151mph i know the car will go 160+ no problem once i get it sorted out.
Old Oct 1, 2007 | 09:01 PM
  #39
OWN3D BY MY PROF!
I guess that's what sucks about living up there. It stays pretty much nice here all the time. The only unfortunate things are the current red tide that's making me cough and the freakishly hot 7 months of the year.
I still think I'd like to swing for one. Is there any time estimate on when we can expect them to hit the shelves? I just ordered my set of All Pros tonight and they're going to need a nice intake.
Old Oct 2, 2007 | 08:40 AM
  #40
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Sick looking intake!
Hey go over and raise the rev limiter on my car! I'll bring over a tv that will fit on your golf cart.
