Something (else) from Dave...
Old Sep 12, 2007 | 12:06 PM
BadAssFast's Avatar
Default Something (else) from Dave...
This isn't the fanciest thing you've ever seen but Dave and crew built it exactly like I wanted it. Photo doesn't do it justice either. This will look great sitting between the polished valve covers. Quick on the motor - LME Nitrous huffing 408 with a custom Futral Cam. Oh yea...this is only one of the two stages controlled by the FJO mini - the other is a 90 mm Nitrous Outlet plate. And yes...my company is Macon-Moore Performance since we don't advertsise here so that is just an FYI explanation on the fuel rails!!
(edit by Moderator: non-sponsor link removed)
Old Sep 12, 2007 | 12:51 PM
slow95z's Avatar
thats just sexy as can be.
Old Sep 12, 2007 | 01:07 PM
sworaz's Avatar
Wow that's great...wanna trade
Old Sep 12, 2007 | 01:25 PM
ToxicFormula's Avatar
Looks great, but I'm confused, how does it work with a fuel and nitrous solenoid on each rail? are the rails separated internally? or is there something that I'm not seeing
Old Sep 12, 2007 | 02:38 PM
Bad Habit Bird's Avatar
Each rail has one path for nitrous and one path for fuel
Old Sep 12, 2007 | 04:12 PM
NVR KNO's Avatar
Very clean setup!!
Old Sep 12, 2007 | 05:12 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
You can tell when you look at the bottom of the right side rail. It has two threaded inputs for solenoids. You can tell that the one on the bottom is on the left and the top one is towards the right.
PS: Looks pretty
Old Sep 12, 2007 | 09:00 PM
BadAssFast's Avatar
Thanks - and yes the inner/upper logs have two length wise chambers. Note this too...when I sent the fuel rails to Nitrous Outlet they were anodized red. I have a black car with no other colors to speak of in the engine bay. Just chrome and black.
It should look good on this...
Old Sep 12, 2007 | 09:24 PM
LS1SpeedAddict's Avatar
I'm new to direct port and I know I see it alot, but wouldnt it be safer to use one fuel and one nitrous solenoid instead of two each? What happens if one nitrous solenoid doesnt fire or one fuel solenoid doesnt fire? I love your setup by the way.
Old Sep 12, 2007 | 09:32 PM
Robert56's Avatar
Hey Macon, since your 408 is still waiting to be planted, i thought you could foward your intake to WA state for some testing on my 408, as it's being flogged now?
Robert
Old Sep 12, 2007 | 09:34 PM
ThunderStruk's Avatar
Looks sweet Macon!!!!
Old Sep 12, 2007 | 10:22 PM
BadAssFast's Avatar
Robert
no soup for you
Sure there is a higher potential for a part failure. If I learned one thing about nitrous systems it's maintanence. I have a tool to disassemble noids. I have had one purge solenoid get some moisture in it from not capping off my purge line. It doesn't take much to inspect and check the noids. Just do it.
Old Sep 12, 2007 | 10:23 PM
BadAssFast's Avatar
I can't wait to hear that big damn cam too!!
Old Sep 12, 2007 | 10:37 PM
GregWS6&z28's Avatar
that is just flippin badass as badass can get
Old Sep 13, 2007 | 01:34 AM
BayAreaSS's Avatar
That looks good!
Old Sep 13, 2007 | 01:43 AM
TwistedSS's Avatar
Macon I might have to swing by the shop and 'inspect' (drool over) that. Excellent work!
Old Sep 14, 2007 | 10:55 AM
Nitro Dave's Nitrous Outlet's Avatar
That sure is one sexy intake set up you have there!!!!
Old Sep 14, 2007 | 11:03 AM
BadAssFast's Avatar
You are always welcome.
Old Sep 14, 2007 | 11:23 AM
Chris@NitroDaves
Guest
Posts: n/a
of it on the motor.
-Chris
Old Sep 16, 2007 | 08:59 AM
BadAssFast's Avatar
Originally Posted by Chris@NitroDaves
of it on the motor.
-Chris
We have to get two cars finished before mine can go back into a bay. Patience is difficult some days.
