Warning! Nitrous Air Fuel Ratio
So you ended up with alittle more then 100rwhp with the 150. Also from it being a hot day. Thats pretty good for a stock car, what a sleeper. Yeah lids help out but not that much for $200. I would rather spend a little more and get a cam if I were still stock.
I wonder what fuel jet I will need, since I have a 340 intank fuel pump I wonder if I will be ok with the 33 or maybe even 36?
Give the guys at NX a call, they are very good at what they do. Your lid will be giving more hp when your engine is gonna need more air with a cam/heads/exhaust. Its a must with mods but with stock engine, it doesnt show a big hp gain.
Also, you want to make sure your fuel system is up to snuff, whether it's injector size (for dry), and what power level your fuel pump can support.
In my case, my Camaro dynos (unlocked T400) like 420RWHP NA, and 550RWHP with a 150 shot. I don't have enough fuel system probably to spray both kits safely, unless I add a boost-a-pump voltage blaster.
14:1 would be unsafe for nitrous, there would be no room for possible detonation.
Assuming a Dynojet, for NA folks might target 12.x:1 assuming that on the street the car would be more in the 13.x:1 range. So carrying this out a bit, if a tuner suggests 11.x:1 on the dyno for nitrous, and it's not a load-based dyno, it's their assumption that the car will run leaner, like 12.x:1 on the track and on the street under full load.
i spray twice that, so i am a little critical about these things, but...once you read ALL of your plugs on a particular tuneup, and get it right, you know whatever your a/f readings are actually reflecting. i hope that makes sense. I had the same problem when I dyno'd with my NX system (with Daves plate) I had to move all the way up to 41 jets to get 11.5-11.8 with 1180 PSI, (and I have a racetronics fuel pump!) but I later found a "slightly" crimped fuel line from the fuel supply to the solinoid
By the way, I picked up 151hp (412-563) with the 150 jets and full bottle at 1180psi
Even though this thread came from the depths of hell I figured since the question had been brought up I'd post here instead of making another thread.
As for the lean is mean that doesn't just entail going as lean as possible. With anything there is a point of dimishing returns. In the case of a motor the return could be a bunch of dead pistons if you go to lean. I would never run a pump gas N/A motor leaner than 12.5. For the few extra HP the risk just isn't worth it, especially with the changes in pump gas from day to day, pump to pump.
I would stay within the time tested ranges, but if you decide to go leaner keep in mind the outcome could be expensive.
