tested halo
Old Sep 14, 2007 | 01:08 PM
00formLs1's Avatar
Default tested halo
installed my racetronix kit and halo bar yesterday.
the halo bar is for a second stage but my buddy has the other solinoid that am going to use so i just used the one from my wet kit.
i had it jetted for 100 and the inital hit was not that hard compared to my wet kit but it pulled very smooth through out the powerband.
i can't wait to try it with my wet shot .
Old Sep 14, 2007 | 01:13 PM
98_Formula's Avatar
aahhhh i seen "tested halo" and the first thing that came to mind was Halo 3... so close, sept 25...
back on topic, your going dual stage on SI ? i wanted to runa setup like that, the halo bar seems like a real nice setup, have to let us know what you think once you get the other solenoid
Old Sep 14, 2007 | 01:35 PM
Nitro Dave's Nitrous Outlet's Avatar
Nice. Did you happen to log the airfuel when testing?
Dave
Old Sep 14, 2007 | 05:00 PM
00formLs1's Avatar
no not yet. i just did i short 25 to 80 pull by my house. once i get the other parts i need i am going to hook up the wideband.
i ran a 200 wet shot and logged it before the new fuel pump about a month ago.
i was seeing 10.6 moving to 10.9 toward right before the shift. did it from a stop till 110.
i was wanting to do 2 stages so there wouldn't be so much of a tourqe spike. if the a/f is still a little rich with both stages then i'll try leaning it out a bit with the jetting.
thanks dave for the great product. i got the filter entry and you can even tell its there. only things that give the system away is the plate and bottle between the seats.
Old Sep 14, 2007 | 05:03 PM
00formLs1's Avatar
also would going down to a colder plug like tr7 be better than my tr6's with a dual stage?
Old Sep 14, 2007 | 06:42 PM
TwistedSS's Avatar
00formls1-
A little off subject, but was that run in your sig with drag radials and a 150 shot??!?!
Never had any experience with the halo...easy to hide though
Old Sep 15, 2007 | 01:40 AM
00formLs1's Avatar
yea that was with some et streets that i mounted on some 15in rims that wern't the right offset so the weight of the car made them butterly out a little.
i armed the system in second. times are low becasue of the altitude, 4200ft.
yea the halo is easy to hide.
Old Oct 21, 2007 | 02:54 PM
BobDoLe's Avatar
i intend to place an order for one of the hidden halo spray bars to resolve my recent dry nozzle placement issues (my swiss cheese lid can only hold so much duct tape) - then i'll post some hptuners data.
Old Oct 21, 2007 | 06:49 PM
00formLs1's Avatar
my lid has a few holes in it. i did a hidden nozzle under the box so theres some tape there.
