Please don't laugh...quad nozzle setup...
Old Sep 14, 2007 | 07:33 PM
scottHMT's Avatar
Default Please don't laugh...quad nozzle setup...
I bought this kit for 350 dollars brand new off craigslist, and figured i could get it to work, its a direct port kit for a 4 cylinder, so i stuck 4 nozzles into the bellow and it seems to be working pretty well, spraying 100shot right now, running a bit rich because i only had feul jets for 150, but id rather run it rich than lean. current mods are as follow
pacesetter uncoated LT
ngk tr6
ram powergrip hd
slp lid, k&n filter
Please dont make fun of me too much
Old Sep 14, 2007 | 08:46 PM
383LQ4SS's Avatar
LOL...I guess whatever works
Actually you should probably eliminate two of those. Youll get a quicker response and probably less lean spike.
Old Sep 14, 2007 | 08:58 PM
scottHMT's Avatar
Why eliminate two?because of the time it takes for the feul to get from the feul solenoid to the nozzle? Whereas the nitrous has 1000psi pressure and gets to all 4 solenoids relatively quickly?
Old Sep 14, 2007 | 09:16 PM
jmill96Z's Avatar
I've seen alot worse. Is it hardlined?
Old Sep 14, 2007 | 09:39 PM
RamAir02TA77's Avatar
Wow thats pretty cool atleast it works. Im sure it will flow alot of hp to.
Old Sep 14, 2007 | 09:47 PM
scottHMT's Avatar
all lines are hadlined except for that one, i didnt have a line long enough to reach, so i used a braided line. It works suprisingly well. What i was going for was more even spray pattern vs dual or single nozzle. HOPING that i may not lean out a cylinder if i have even dispersement like a plate kit.
Old Sep 14, 2007 | 09:53 PM
Reject's Avatar
lol that's awsome
Old Sep 14, 2007 | 09:57 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Originally Posted by reject
lol that's awsome
I agree it is weird, but pretty cool at the same time. Definetly not bad for $350.
Old Sep 14, 2007 | 10:24 PM
scottHMT's Avatar
Also came with 15lb bottle with high flow valve.
Old Sep 15, 2007 | 12:04 AM
Robert56's Avatar
Wow, I thought I was unique with my quad dry nozzles, very cool. The volume of fuel needed to fill all the lines could give ya a lean spike worse than normal, that's what I believe Al was getting at.
Robert
Old Sep 15, 2007 | 01:23 AM
ApexVIII's Avatar
wow, thats a lot of spray lol
Old Sep 15, 2007 | 09:45 AM
That might work nice with a standalone system as you can have the system primed and get like no lean spike.
Old Sep 15, 2007 | 04:07 PM
scottHMT's Avatar
Im aiming to get it tuned soon so i can turn up the jets to 150shot. Just need a feul pump and im set to go.
On a side note. Nitrous ls1 > pulley exhaust terminator
Old Sep 15, 2007 | 04:21 PM
scottHMT's Avatar
Would it be better if i ran 4 nitrous nozzles jetted for 25 and 2 feul jetted for 50?
Old Sep 16, 2007 | 08:33 PM
chad rock's Avatar
I love the idea with a stand alone but your problem is 58psi with 4 seperate nozzles is going to be extremely rich .If you look up jets for 25 hp nos single nozzle for 58 psi(holleys web site) then do that 4 times you have alot more fuel than nos ,it just doesn work that way.If you want to make the hp that the 4 nozzles total you will probably have to drop the fuel side in each nozzle 2 to 3 jet sizes.I wouldn do this without a wideband.When you stack kits which is basically what your doing they usuall go pig rich.I know this because I have more than one nozzle. hope this helps
Old Sep 16, 2007 | 08:35 PM
chad rock's Avatar
If you can get the tune rite 11.5 to 12.0 I think you will have great sucess with the 4 nozzles
Old Sep 16, 2007 | 11:39 PM
Robert56's Avatar
The math for converting single nozzle to dual nozzle jetting is in the lead post (IIRC) of the jetting sticky. It's not half size like one would think. If ya can't find it let me know and I'll post it.
Robert
Old Sep 16, 2007 | 11:43 PM
BayAreaSS's Avatar
Thats pretty unique!
Old Sep 16, 2007 | 11:54 PM
joblo1978's Avatar
"Nitrous isn't for amateurs, I've seen how you drive, you gotta heavy foot, you'll blow yourself to pieces."
Old Sep 17, 2007 | 12:31 AM
scottHMT's Avatar
Oh really? I figured if .14 and .26 was ~ 25hp/shot then x4 would equal 100 shot? I think i'll be investing in a wideband soon. It does have a extremely noticable hesistation when the nitrous hits.
