Spraying at 2000 RPM's
Old Sep 15, 2007 | 01:48 AM
MyTA99's Avatar
Default Spraying at 2000 RPM's
Anyone ever spray at 2000 RPM's? What happens? I sprayed a 100 shot at 2000 tonight by accident. Just wondering how many others have done the same.
Old Sep 15, 2007 | 02:06 AM
99Silverado5.3's Avatar
Gets out of the hole a lot quicker with tires, otherwise spins real bad.
Old Sep 15, 2007 | 02:32 AM
MyTA99's Avatar
Default First track experience with NOS
Well I went tonight and am very pleased with the results. I made 6 passes total. The first 2 were on the bottle, and the others were NA. I was spraying the 100 jets. First pass on the bottle I went 12.575 @113.42 with a 2.064 60 ft ( I think I sprayed at 2000 RPM's opps). The 2nd with spray I went 12.969 @ 112.85 with a 2.277 60 ft. My best NA for the night was 14.192 @ 103.10 with a 2.324 60 ft. My best NA before the retune for NOS was 13.7 at 105 with a 2.2 60 ft. I can't wait to see what the 150 jets do.
Old Sep 15, 2007 | 08:46 AM
Matt@HSW's Avatar
Those are some pretty good results, congrats! Now get a RPM window switch so you don't activate it too low in the RPM band (3000+), very bad things can happen.
Matt
Old Sep 15, 2007 | 11:43 AM
mrr23's Avatar
i've done 150 repeatedly as low as 1800 rpms. at 1800, the tires spun. at 2000, hooked and went.
Old Sep 15, 2007 | 05:06 PM
quickblade's Avatar
So, the dynotune kit... What else am I going to need to get it up and working good.
I keep seeing the window switch deal... What is the window switch going to do for me... Is that the WOT censor deal?????
Old Sep 15, 2007 | 05:25 PM
99FormulaM6's Avatar
you set the window switch to only spray n2o in a certain rpm 'window.' ie, set the switch for 2800-6100 and thats only when the kit will spray. wouldnt wanna spray too low and blow up your intake...
Old Sep 15, 2007 | 05:55 PM
quickblade's Avatar
Oh.. dahhh...... Window switch.. being in the window set...
LOL... anyways.. been a long day of work... not thinking....
Thanks for the info on that..
Old Sep 15, 2007 | 11:15 PM
SPEEDYTRANSAM1996's Avatar
i hit it with a 150 shot right outa the hole with a 158 60ft time
Old Sep 16, 2007 | 01:19 AM
TwistedSS's Avatar
Not a fan of spraying below 2500 or so.
