Lid for N2O?????
I am in the boat of do N2O first, then heads, cams, rollers, rods, etc.
so I can then add a 2nd stage.
The lid looks good, but if my only benefit is a few horses, not too interested.
But if there is an advantage for running my N2O, then I will lid and N2O same time, but if no advantage. I will place N2O on order.
If you think it is heads, cam, rollers, and rods that will allow you hit a 2 stage you are mistaken and you may need to do some more reading up my friend.
IMO sounds like you are jumping into nitrous without much knowledge of these motors, no offense.
I know what is needed for running 100 shot 1 stage of N2O, not really anything, execpt like the lean kill switch, and what not that you connect with the N2O setup.
Yeah, for the 2nd stage I need tons done... Not even going there yet..
But for 100 shot stage 1, I should be set.. well doing NGK tr6's for my plugs, not touching fuel, for what I have seen dont need to worry yet.
I have read that I can safely install a 100 wet shot on the car... All stock, nothing done, and that would be fine... I have a buddy who also has a 150 wet shot and has no issues....
There is a few threads of people doing nothing on their ls1's and putting a 150 shot with no problems... Of course when you are sparying you will have to be safe and not go all crazy...
600 dryshot, um did you mean 60 dry... Cuz 600 sounds a little crazy to be doing that on a stock motor...
but for the time being I am putting 100shot, stock everything. Will do any adjusting afr with wide band. I will have 150shot nozzle also, and 75, but will run 100 first time out to play with, and do any adjusting I need to do.
of course will have my fuel/air kill switch that you can get with the dynotune kit.
Never had spray, but does not seem that hard.. Gotta be smart about it.. If I got spray 9 years ago, I would of dogged something out...
But I am cautious, but with spray, no one ever knows.. You can do all you want, but it seems that if something is going to go wrong, you will not have control of it..
well you will have a cut off switch to try and not damage alot....
Most retarded comment about n2o I have ever heard.
If any of you sponsors who sell n2o are watching, do not sell this person any nitrous. I would hate to see him blow up his motor because he has the non-chalance-ness to think that you dont have control over things going wrong.
What I'm saying is it's a contributor to the total package and is probably worth it. Buy the lid, and then keep on adding mods.
OK, so since maybe I did not say that correctly.. BUT What I am saying is, even if you do all the tuning you need to do, and for some reason you get a hiccup/back fire in the intake.... WHAT you are saying is you will be able to control that.... That is the control I am saying you dont have control over.
But since you feel you can have control over this... please inform me...
Because I know peeps with N2O and if something happens that will cause a problem, and you are racing, well, boom.
So please inform me of how you would have control of a back fire in your intake???
