HSW Plate, best out there?
I see that it sprays in a full 360 degree pattern, which seems to be the best for atomization and not leaning out a cylinder. Do the other plates do this aswell? or is the HSW plate the only one. Cuz if so, looks like i'll be ordering one. 4 Nozzles was just a PITA
![Disgust](https://ls1tech.com/forums/images/smilies2/disgust.gif)
I like the concept of Matts plate as well, although I am using Dave's Plate and it works great...Matt has come out with some cool stuff since I got started a couple years ago
I would wager a case of Shipyard Pumpkin Ale...that the NOS Plate, The HSW Plate, and the Nitrous Outlet Plate would be within a couple % HP of each other in a head to head test (same jetting same pressures etc). Just as in the Wet nozzle test, most nozzles were so close performance wise it was hard to say as to which is better...
Bottom line is the consumer has more choices now, so its a win-win situation
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Originally Posted by Boodyrider
Hmmm, yeah, but even distribution to all cylinders is NOT optimal with LSx style intakes. Carb style intakes improve cylinder distribution.
As far as limited to what you ask, 360 is better than not.
I have Daves plate and I'm very happy with it so far, It hits much harder than the dual nozzles I had.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
IMO the spray pattern will have little to do with anything. You could easily make a case for HSW's pattern...or Daves pattern. And unless you checked via wideband or EGT in every primary...its all speculation. I dont see any advantage of one spray pattern over the other.
I bet they both work and both work great.
And as Beer said...HP will be directly related to nitrous flow. IOW they will be the same as far as power output.
So pick the one you like and go for it.
Originally Posted by 383LQ4SS
BTW I think ALL the plates are better than single nozzle setups.
Depends how you're tuning.... sometimes the cooling of the nozzle, directed at a specific point not quite dead on the MAF sensor, is used to tune, in which case you want a single....
Apples to Oranges, your comparing Dry tuning to a Wet System. The plates in topic are all for wet systems.
Wet systems are easily tuned by swapping the fuel jet up or down to get the desired AFR.
Nitrous delivery systems do what?
Deliver the product(s) right?
Just a means to emulsify nitrous and fuel (wet system) and introduce it to the air stream right?
Considering that it (nitrous) boils and turns to a gas almost immediately after hitting the high velocity intake charge I doubt it would matter much on how the spray pattern is.
The best way (only way in my opinion) to really conclusively tell the complete performance of each system is as described above. Side by side heads up tests with all parameters equalized.
But you must add one thing. EGT sensors to each exhaust port. This is going to tell you the real story behind how one plate distributes over another.
Be interesting to see how a fogger nozzle compares to a plate.
JMHO
JMHO
Well im not gonig for the most power, but the 'safest' power. I would like my engine to last for a little while and a plate system seems much better than what i had. So i was trying to guage input on people that had them.
![Lurk](https://ls1tech.com/forums/images/smilies3/lurk.gif)
Robert
Edit: Even a DP will have varing EGTs, and must be tuned per cylinder to get them close. But from the testing that has been done (not by me) a dry hit before the MAF will in fact have closer EGTs than a tuned DP. My point, prob any wet hit will have variations, however, will this 360* pattern minimize the EGT flucuation and get it closer to a tuned DP, or maybe surpass it from the get go? Input?
