Dyno graph and nitrous...
Old Oct 3, 2007 | 09:39 PM
01'WS6's Avatar
Default Dyno graph and nitrous...
Does this fueling seem right to everybody? It seems a bit off to me. And if so what would u suggest tweaking?
Old Oct 3, 2007 | 09:43 PM
waterbug1999's Avatar
I would say a little rich... Mine was at 10.1 1st time I sprayed. I think target, from I have been readin is around 12.1.
What shot you runnin?
And is that an auto?
Old Oct 3, 2007 | 09:46 PM
383LQ4SS's Avatar
what kind of setup is this? You have a bit of a lean delay..then it goes rich. I would leave it alone.
Old Oct 3, 2007 | 09:51 PM
01'WS6's Avatar
It's an auto and a NX wet "175 shot". Weather or not its a true 175 im not sure since the jetting is hybrid and there isn't a generic 175 shot listing from NX. It's just a basic bolt on car with a 233/239 cam on a 112+2 lsa, stock 241 headed car.
Old Oct 3, 2007 | 10:00 PM
It might be a little low on 175 N20 HP, but not by much..
I dynoed mine N/A and it was 427hp (4K stall auto) and then took out timing and it went down to 397. Threw on the 100 shot and made 507. But, this was all with everything pig rich, 10.5 A/F on motor and 10.1 on the spray. Working on the tune for awhile and its better so I am sure I added some HP across the board. Will find out as I am headed to the track this weekend.
Old Oct 3, 2007 | 10:03 PM
01'WS6's Avatar
It dynoed 376 rwhp N/A through a 3500 stall, moser 12-bolt and 3.73's and then the numbers u see above on the "175 shot".
Old Oct 3, 2007 | 10:08 PM
Well, it comes out to 551 and you are at 537, so its pretty damn close...
Also, I am still on my 10 bolt as well.. So that does not eat up as much HP as your 12 bolt.
Old Oct 3, 2007 | 10:10 PM
Have you been to the track yet?? you gotta go and spray that bad boy, your gonna like the launch!! Maybe even wheels up!
Old Oct 3, 2007 | 10:39 PM
01'WS6's Avatar
I've taken it on a nasty night and it went 11.1 full weight, nothing has been taken off for weight reduction. Next time out im gonna run some 26" instead of the 28" tall tires that i have been running because it had quite a few extra rpms left on the big end to go. The launch wasn't bad with some high 1.5 60's and it felt real good. As far as wheels up launches my sway bar is still connected and my TTII's up front kinda keep it closer to the ground since they are so damn heavy. It usually pulls the tires about 4 inches though.
Old Oct 3, 2007 | 10:45 PM
Yea, you got to take that sway bar off.. It does help with weight transfer. Im still surprised my 10 bolt has lasted with multiple 1.5X 60's on N/A and 1.45 60' on teh juice. I hope I did not jinx myself by saying that.
