Bigger injectors for nitro?
Old Oct 5, 2007 | 10:31 AM
Thule's Avatar
Default Bigger injectors for nitro?
i am installing a SVO #30 (36lb's) in my motor,
is it better for me to go bigger because of th nitrous?
Old Oct 5, 2007 | 11:15 AM
jmill96Z's Avatar
If you're going with a wet kit you'll be fine.
Old Oct 5, 2007 | 11:37 AM
Thule's Avatar
is that your car in the avatar?
can you send me some pics
Old Oct 5, 2007 | 11:51 AM
jmill96Z's Avatar
Yeah, that's mine. I'll see if I can find some.
Old Oct 5, 2007 | 04:54 PM
DuronClocker's Avatar
If you think you'll ever have the idea to run a dry shot on your motor...definitely go bigger, at least 42#'s.
Old Oct 5, 2007 | 07:36 PM
Thule's Avatar
this is a wet kit
Old Oct 5, 2007 | 08:03 PM
b00sted's Avatar
What about a 125(rwhp) dry shot on an 01 car? Stock injectors & pump. I've seen plenty of stock LS1 cars handle it fine...Think there will be issues?
I guess make a test rip and pull a few plugs to see if it's lean. I wish I had a WB02.
Old Oct 5, 2007 | 08:30 PM
NVR KNO's Avatar
Id get the injectors just for the peace of mind. I put 42lbs on mine, granted Im on a dry kit. But Id do it anyways....
Old Oct 8, 2007 | 09:31 AM
Chris@NitroDaves
Guest
Posts: n/a
You will be fine with the 36lber's with the wet system.
-Chris
