Dynotune.. Omfg... Woohoo!!!!
Thanks a bunch John...
So if anyone can look at this and tell me what the deal is.. That would be great..
Any advice on what I need to be doing next, would be great...
Looks like you stopped spraying just a few mph from hitting the 110 limiter. Also a good thing you didn't spray till 2nd gear so you missed the RPM limiter at the top of first.
I bought the car with 40,000 miles on it, and was 1 owner... but they did not mention the tune, and gears..
I only found this all out today doing all the research, and looking at logs.
thanks alot for all this input..
I appreciate it.. and will use the information wisely....
timing increased 3-4 degrees from 1000rpm to 6000rpm during wide open throttle - might want to take out a degree where it goes above .76 g/cyl between 3000rpm and 6000rpm because a little knock is registering.
your 3-4 shift is commanded at 103mph as low as 56% throttle... ok so that sucks *** because your 103mph comes on at 5200rpm - but you see it keeps going because its actually waiting until the programmed shift point of 5700 where you're hitting 110mph. the tranny tune looks like it was setup for 4.10 gear for the 3-4 shift... but your 2-3 was set to 5763rpm at the correct 69mph.
stock with 3.23 gear, your 3-4 shift should happen at 125mph (about 120mph with 3.73 gear) at full throttle and about 118 at 56% throttle which is 6000 rpm.
you're going to want to at least raise the shift points to 5900rpm on the 2-3 and 3-4 shifts.
your shift speed (time it takes to go from one gear to the next) has been sped up very very slightly, but the 2-3 shift is nice at .250 during wide open throttle.
shifts have also been firmed.
something i noticed about the log file is that your bottle pressure appears to be dropping pretty quick - was the bottle almost empty on that run?
So umm.. yeah, my bottle was pretty low...
lets put it this way, I got home, and pretty much with the bottle nut open,
took the nozzle off. LOL..
She was empty.
Here is me getting a GTO.. 04 GTO..
again I should have better runs, but because of the tune that was in there, messing me up.
