View Poll Results: better???
high fule press
5
55.56%
low fule press
4
44.44%
Voters: 9. You may not vote on this poll
Stand Alone qustion
Old Oct 9, 2007 | 10:22 PM
Ego Killer's Avatar
Default Stand Alone qustion
Iam thinking about getting a stand alone for my nitrous..I have a direct port and want to spray 200-300rwhp shot..soin the stand alone I'll have c16 but should I run high press or low press.? I have been told that the low press. hits harder but witch is better? and why..and what shoud I set it at on each?
Old Oct 9, 2007 | 10:49 PM
Robert56's Avatar
Low pressure cause you can run a jet with a bigger orifice, compared to high pressure and a smaller orifice for comparative sized hits. Why is this important, the smaller orifices have a greater tendancy to get plugged up, and that could be a major melt down.
Robert
Old Oct 9, 2007 | 11:30 PM
Ego Killer's Avatar
Robert
Thanks,Im gonna start just PM'n you. seems like you always anwser my n20 questions..LOL what should I set the fule press. to?
Old Oct 9, 2007 | 11:38 PM
Robert56's Avatar
Just contact whom evr ya got the standalone from. usually, IIRC it's somewher around 7psi, but you can fine tune the psi as part of your setting up of a low pressure system, so get their rec first.
Robert
Old Oct 10, 2007 | 03:00 AM
jmill96Z's Avatar
This may sound retarded (flame suit on) but are nozzles designed for a certain psi of fuel to help maintain suspension?
Old Oct 10, 2007 | 10:20 AM
Chris@NitroDaves
Guest
Posts: n/a
Also a low PSI system is easier to tune becasue you are able to get better results out of a samll PSI adjustment ( 2-3 PSI ) where in a high pressure situation you wont get the same results. Also keep in mind that if you already have a system for high pressure then you will need to get the appropriate jetting / jets for the low pressure.
-Chris
Old Oct 10, 2007 | 02:38 PM
02NBMWS6's Avatar
ive also heard that low pressure will help alleviate lean spikes. doesnt make much sense to me, is there something to that?
Old Oct 10, 2007 | 06:05 PM
Nitro Dave's Nitrous Outlet's Avatar
No I dont see how low pressure would get rid of a lean spike. You would think that high pressure would move the fuel faster there for being better to illiminate a lean spike.hmmmm
Old Oct 10, 2007 | 06:06 PM
To add to the above info..
If you plan on using a certified flow gauge to adjust flowing fuel pressure low pressure may be the only way to go since I am not aware of anyone that offers a high pressure flow gauge.
Dave
