Timing tuner Question????
Old Oct 16, 2007 | 11:02 PM
import slayer's Avatar
Default Timing tuner Question????
Is anyone using this timing tuner and if so how do you like it?
http://www.thunderracing.com/catalog...vid=3&pcid=304
Old Oct 17, 2007 | 09:48 AM
Chris@NitroDaves
Guest
Posts: n/a
I'm running one on my car and I love it. It allows me to run the Max timing for the best NA hp possible and with the flip of the arming switch it will take out the timing needed for the size shot i'm running.
-Chris
Old Oct 17, 2007 | 10:28 AM
01Z28M6's Avatar
I have one on my 01. Currently it does nothing because I can tune the car with my predator. However, when the nitrous is installed I will be able to create a timing window for spark retard and solenoid activation. How that will work remains to be seen but I don't anticipate a problem from the TT.
I advanced timing a few degrees and tested the car; it lost power so I set it back. If I had needed the timing I'm sure I'd be expressing how everyone should have it.
Old Oct 17, 2007 | 01:01 PM
wyndzer's Avatar
Got it, Love it, would do it again.
Old Oct 17, 2007 | 01:08 PM
VH5150's Avatar
Dynojet Fan
Ive got one too, bad *** unit..... Its kinda tricky to hook up if youre not into wiring.. BUT nitro dave's or mike at full-throttle (both sponsors) can help you wire it up...Mike @ Full-throttle acutally makes the timing tuner... Just got off the phone with him, great guy very smart.....
Old Oct 17, 2007 | 03:06 PM
Thanks for all of your input. I will definitly buy it!!!!
Old Oct 17, 2007 | 06:20 PM
JEB99TA's Avatar
I can tell ya' in two weeks. Mine's wired in and mounted ... just waiting to get the car in for final wiring inspection and nitrous tune.
Old Nov 1, 2007 | 09:07 PM
let us know how you like it
Old Nov 1, 2007 | 09:26 PM
david vericker's Avatar
The timing tuner works great. Pulling the desired timing out is one thing,you can also set the nitrous to activate at a given rpm with a 0.0 to 0.8 delay that works off of the WOT switch.
Old Nov 2, 2007 | 08:39 AM
Joey@Tick's Avatar
LS1TECH Sponsor
I'm using the timing tuner to pull 3° when my arming switch is flipped, and I use it for my window switch as well. Very neat, effective nitrous tool.
Old Nov 6, 2007 | 07:31 PM
1BADAIR's Avatar
I love mine. JUst wish it would control 2 stages
Old Nov 8, 2007 | 10:34 AM
I didn't know that you could use it as a window switch.
Old Nov 8, 2007 | 11:28 AM
01Z28M6's Avatar
Yeah, it's really got all the base stuff for nitrous timing and switch control. It would be totally **** if it had some kind of display like Mallory's Hyfire VI - which I have on my 95 Z28.
Old Nov 9, 2007 | 02:57 PM
1lejohn's Avatar
I've been running mine for about 5 years. It works great for N2O. Mine sometimes flakes out and the car won't start, so I have to bypass it with the supplied jumper. This seems to happen if I start the car a bunch of times in a row, like when you are waiting in the staging lanes. I might try the new MSD timing twister. I have their window switch and it works good.
Old Nov 10, 2007 | 07:29 AM
01Z28M6's Avatar
I wouldn't think you would need a separate window switch. Speaking of the MSD alternative, I thought to add a little more to my opinion on the Timing Tuner. It just looks a little too home made for a $250 performance component. The radio shack project box and glob of black rtv to seal the wiring coming out the hole just doesn't do it for me. The 4 tiny screws into the plastic walls of the box that hold the lid over the little switches and rotaries also leaves something to be desired. At the time, it was the only game in town for LS1 timing control.
Old Nov 10, 2007 | 07:55 AM
1lejohn's Avatar
I'm using the MSD switch to lock up the converter in 3rd gear.
Old Nov 10, 2007 | 08:02 AM
01Z28M6's Avatar
Anyone who passes through the traps at 132 mph knows what they are doing.
Old Nov 10, 2007 | 03:33 PM
00turboT/A's Avatar
I have one and love it. The thing is bad ***. I knwo some of the earlier one about 2 years ago had some issues but all that is worked out now and they work killer
Old Nov 10, 2007 | 07:50 PM
01FbTaWs6's Avatar
this sounds like the way to go IMHO! Its got all the bells and whistles neede to run N2O! Delay, window switch, AND pulls timing apon activation! thats impressive in itself. Nothing like being able to run the best you can on motor, then flip the switch, and have your N2O tune right there without having to reflash.(assuming yoru running a slightly bigger fuel jet in the N2O to compensate for the difference in a/f ratios)
Old Nov 11, 2007 | 07:11 AM
01Z28M6's Avatar
Here's a used one being sold by a member now.
https://ls1tech.com/forums/lsx-parts-sale/813078-nitrous-timing-tuner-ignition-timing-controller.html
