Custom Nitrous & Fuel lines
I want to purchase more trust worthy lines, but I haven't decided on what type of line. I'm considering the following prefabricated lines; black hose (same stuff that came with the kit), braided lines, or maybe even mandrel bent hard lines. This is a direct port wet system so we are talking about 16 lines. Any comments, recommendations or examples? Yes, I know it's not going to be cheap so if anyone can recommend a place that will give me a good price, I'm all ears.
http://www.ormebrothers.com/
If you want to switch to hardline or braided hoses we can do that for you as well.
You would just need to send us your intake and system.
Let me know if I can help in any way.
Dave
I have a 16' Dynotune 4an nitrous line that I want to shorten to 9 feet. I have called every hose company in my area. Nobody can do such a small line. They don't have the die for it. They can do 6an all day. But I don't see myself ever spraying above a 200 shot of nitrous.
What are my options? I can have one made for $50 from Harris, but is there a way to cut my line and rig something up myself? Will it safely hold 2000psi if needed?
Why would you expect it to hold 2000 psi?
I think I may have found a hydraulic shop that can crimp a line with a 3/16" ID and 5/16" OD. Most hydraulic shops can't go that small. I am going to pay them a visit to see if they can do it for me.
But I had no idea that a compression fitting can handle 1000+ psi.
Thanks for the info. If I run into any more problems, I'll contact Chris as recommended.
Like suggested abvove I know summit sells a fitting for doing it yourself. I have never looked at it but I have talk to people that did it.
Dave
Dave
I went ahead and shortened my hose from 16' to 9' and put a fitting on both hoses so I can have a spare if ever needed. The fittings were $15 each! It cost me $38 to have two fittings crimped on. Only took 10 minutes. I could have a bought a brand new 9 foot hose for $45. But, at least I found a local shop that has the ability to make hoses for me. Next time, I will get my own fittings and bring them in.
