Completing wiring ... need two things ... please help if you can.
Old Oct 22, 2007 | 08:18 PM
JEB99TA's Avatar
Default Completing wiring ... need two things ... please help if you can.
It's almost done. Can anybody help me with these two things? Any pictures would be appreciated very much.
1. Pillar pod fuel pressure gauge and air/fuel gauge > thin red and black wies ... where do they go?
2. How about the dash wiring for the fuel pressure gauge ... how do I tap the black and white wires into the dash wiring?
Please assist if you can ... thanks.
Old Oct 22, 2007 | 10:55 PM
00formLs1's Avatar
by dash wireing do u mean to controll the light with the dimmer switch?
the fuel pressure gauge should have a harness with a sensor, the two wire are going to be your ground and power. black = ground and red= 12v power. to control the gauge light with the dimmer switch you have to tap into it.
Old Oct 23, 2007 | 02:07 AM
Beer99C5's Avatar
Manufacturer of the gauges may help.
Old Oct 23, 2007 | 02:34 AM
TwoFast4Lv's Avatar
I JUST finished installing a full set and I could not tell you the answer. I am not sure what the question is
Old Oct 23, 2007 | 05:13 AM
JEB99TA's Avatar
On the A/F gauge, the harness with sensor does have a black wire and a red wire to the sensor, but, there is another red and wire coming out of the back of the gauge to provide power from the car. It also has a thicker black wire and a thich white wire to tap into the dash wiring. I just don't know which wires underneath the dash are the dash lighting wires.
I'll post up a pic here later today. I just need to know which wires underneath the dash that these gauge wires should be spliced into ... to draw power from.
Thanks Jim. I have the instructions, however, they are not car-specific as to what color wires from which harness to splice into for power under the dash.
Basically, I'm just needing a picture to see where the wires from the gauges are connected to to get power from the key'd ignition source so the gauges come on when the switch is on ... on someone's F-Body setup.
Thanks for the replies fellows. Any pics of your wiring connections would be really helpful.
Old Oct 23, 2007 | 07:35 AM
00formLs1's Avatar
why don't you have instructions?
Old Oct 23, 2007 | 12:15 PM
JEB99TA's Avatar
I have instructions from Autometer.
Old Oct 23, 2007 | 03:28 PM
00formLs1's Avatar
get your self a test light or a volt metter and find a good 12v source, i spliced mine right into the dimmer switch, so when i turn my lights on the gauge lights also go on. if i dim my dash the gauge lights dim.
Old Oct 23, 2007 | 04:37 PM
JEB99TA's Avatar
I have a good multimeter ... don't know why I didn't even think of using it. Thanks for the dimmer switch wiring info. That's perfect for the white and black wires for the gauge light. I'll break out the multimeter and check out a good source for the red and black wires. Thanks for the info!!!
