spray a stock LS1
Old Jun 10, 2003 | 10:53 AM
Fast Eddie's 02 T/A vert.'s Avatar
Default spray a stock LS1
Can i use the bottle on a 02 T/A w/lid and a catback.
Old Jun 10, 2003 | 10:57 AM
BlackEcho's Avatar
Default Re: spray a stock LS1
i believe so as long as you use a conservative amout. I would go no further than a 100 shot
Old Jun 10, 2003 | 03:41 PM
CAT3's Avatar
Restricted User
Yes you can, I have sprayed dozens of 100shot bottles and recently after a walbro255l pump install a couple bottle @ 150. Use the appropriate safety measures, be conservative and if available auto-tap to check A/F and have fun.
Old Jun 10, 2003 | 05:29 PM
needmoremoney's Avatar
Go for it, and have fun.
Old Jun 10, 2003 | 05:52 PM
DJ's Avatar
DJ
i'm running open lines with the 5177 powershots, and everything is holding up just fine. Just be sure to use atap at the least, and a wideband if possible. A MAF-T might be needed if you go up from 125 jets, just read your 02's and change your plugs. Good luck, later-dj
Old Jun 11, 2003 | 10:46 PM
jhelms's Avatar
Cool... what gains are you seeing on the dyno with those open 5177's?
Old Jun 11, 2003 | 11:07 PM
The Guy in MY 99TA's Avatar
I was wondering the SAME thing...
Wouldn't that be around a 600 shot or more?
Josh S.
Old Jun 12, 2003 | 08:06 PM
B18B1LS1's Avatar
The powershot solenoids have a VERY small orfice. Wide open they flow enough nitrous to make around 150 rwhp on a bolt-on car.
Jeffrey
Old Jun 12, 2003 | 08:40 PM
red jet's Avatar
no problem I sprayed 125 single nozzle dry with just a "MTI" lid and borla cat back for a long time now the car is sold with just over 30k miles and drivetrain is still holding up. oh by the way spraying of the line I went 11.71 @ 119mph with just a lid and cat-back have fun and enjoy spanking
vipers and 03's cobra's cause I did!!!!
