how quick should i be w/my new set up?
Old Oct 19, 2007 | 12:10 PM
Thule's Avatar
Default how quick should i be w/my new set up?
i got at least half year to think about it..
but i would like to hear some opinions..
my car has never gone to the track after modds,
went low 13's bone stock, 98 M6
what time and speed should i be able to get?
modds,
built 346cid
patriot stageII ls6 heads, 59cc
double valve springs'
chromoly push rods/ls7 lifters
226/226 585.585 112LSA cam
Harland sharp roller rockers 1.7
FAST 90mm
NW 90mm
FAST fuel rails
FAST fuel lines/adapters
SVO #30 injectors
85mm MAF
lid
pacesetter LT's
off road Y pipe
SLP lm1 catback
did the 98 knock sensor modd (new style)
i got a racetronix fuel system w/voltage booster
90mm plate system from nitrous outlet 150shot, wet kit
i am.. most likely forgetting something,
but its basycly a mild H/C/I car w/ all the bolt ons, free modds, and 150shot
what time and speed should i have as my goals for next summer?
Old Oct 19, 2007 | 01:59 PM
transamfreak01's Avatar
well as long as you get a tire on the car and dont blow out ur rear end or trans i would say 11's no problem
Old Oct 19, 2007 | 05:39 PM
scottHMT's Avatar
+1
Old Oct 19, 2007 | 10:13 PM
capn smokey's Avatar
10s are possible with a hook but mid 11s should be expected with atleast a 124mph. It all depends on the efficiency of your setup, some h/c/n guys have done 130+mph trap speeds.
Old Oct 20, 2007 | 02:30 AM
BAKED's Avatar
Auto with good converter, low 11's, high 10's at around 125 mph
M6 with average driver, mid to low 11's at around 128 mph
Old Oct 20, 2007 | 05:53 AM
HaulinHawk's Avatar
Your gonna need a 9 in and some more gear also!
Old Oct 20, 2007 | 09:23 AM
BLK02WS6's Avatar
10.7's to 12.5's - all gonna depend on if it hooks and if you can drive... All the power in the world won't do you any good if you can get it to the track or drive it down there (M6)...
Old Oct 20, 2007 | 12:06 PM
jmill96Z's Avatar
I think it'll be good for some solid 10's
Old Oct 20, 2007 | 01:15 PM
1320 killer's Avatar
low 11's imo. but it depends on tires and launch
Old Oct 20, 2007 | 02:01 PM
Dr Pookey's Avatar
ur get a high *** bill
Old Oct 20, 2007 | 02:33 PM
Thule's Avatar
the car is a M6, i will have good set og slicks,
biggest question is if i can install a mooser w/ 4,11
i was hoping for high 11's N/A
Old Oct 20, 2007 | 02:58 PM
streetassasin's Avatar
dont run slicks unless you have the 9''
with the 9'', driving it like a man possed: 10.7-10.9 @ 127-129mph is my guess
