Head Choice for Spraying Bigger Hits
not sure about atv?
as for me, right now im leaning towards the etp ls7 style 6 bolt heads
If you go 4 bolt (which you must with the L92) just make sure you have ARP heads studs and it should hold the 300.... unless you want to spray at 2500-3kk vs 3500+rpm.
That is my take... I think the intake design/cubes/stroke has a greater impact on lifting the heads than the deck thickness.
Just dont mushroom a valve.... get some REV Valves as cheap insurance on the L92.... and be done with it!
Robert
Stock L92 Heads
Lift.....intake.....exhaust
.200...160.........122
.300...214.........173
.400...268.........200
.500...302.........216
.550...315.........222
.600...319.........226
.650...321.........229
Ported L92 Heads
.200...164.........130
.300...228.........179
.400...280.........223
.500...317.........252
.550...335.........260
.600...350.........266
.650...357.........270
.700...357.........274
Robert
.100: 79/60
.200: 160/117
.300: 228/195
.400: 288/214
.500: 323/221
.600: 354/232
.700: 363/238 (278 with 1 3/4" pipe)
they are milled, and i am going to hit the motor with probably a 300 shot, i have L19 head studs on right now, i dont want to spray any more than 300 cause i dont know if the heads will lift or not, hell they might lift with the 300 shot.
240/252 .650/.661 114+3 comp cam on LSK lobes.
.100: 79/60
.200: 160/117
.300: 228/195
.400: 288/214
.500: 323/221
.600: 354/232
Robert
These are the numbers from my bench(Greg Good). 28", 4.030" bore, and no pipe on the exhaust port.
Intake Exhaust
.200" 148 117
.300" 228 160
.400" 301 196
.500" 339 247
.600" 354 263
.650" 354 269
.700" 355 272
I spray a 200 shot and she flat hauls ***!
....Why would they, if accompanied with nice studs/gaskets be any more likely to lift if ported?-Will
After porting:
238@ .300 intake
297@ .400 intake
360@ .600 intake
369@ .650 intake
257@ .600 exhaust (no pipe)
Ran 6.48@ 108 on a 200 shot full weight. No traction problems... converter sucks *** IMO.
Robert
converter problems? just buck up and put a stick behind that beast
thank man, it should be decently quick, i wont be up there with the big guys, cause my car is still a fully loaded street car with a 6 speed. but it will be a hell of a lot of fun.
i burnt one pistion last year, never even melted a plug this year and my 346 was still in 1 piece when i took it out and sold it. what motors did i melt down?
and no i dont think the welding i did to the deck did anything. i had it tested, and i have also spoken to alot of racers who have done the same things with no issues on much more motor then me. but again, i realy dont care, its over and done with.
