Nos Experts Advice Needed!
Old Oct 25, 2007 | 01:38 PM
scorpion_z28's Avatar
Lightbulb Nos Experts Advice Needed!
I Have A Supercharged 6.0l Gto With Low Compression Rods & Pistons That Put Me In The 8.9 Compression.
My Question Is Will It Be Safe To Hit It With A 400 Hp Shot Of Nos??
Old Oct 25, 2007 | 01:55 PM
sonic snake's Avatar
I'm no expert,but I don't think that is a good idea!
Old Oct 25, 2007 | 02:23 PM
383LQ4SS's Avatar
there is a TON more to it than that. There are lots of particulars you need to figure out than just "hit it with a 400".
The short answer as you asked it is no. Not even remotely.
Keep reading the thread on big shots. There is much to learn.
Old Oct 25, 2007 | 02:53 PM
02NHRAtransAm's Avatar
im no expert but i would have to say no
Old Oct 25, 2007 | 02:59 PM
What could be the problem if i do it with proper tuning??& i've got a low compression engine.
Old Oct 25, 2007 | 03:05 PM
383LQ4SS's Avatar
are you saying you have the supercharger on it now??? What HP are you making now?
There is a ton more than just spraying a 400 down the pipe. It doesnt matter if your motor is forged. A forged motor can be destroyed just as fast as a stock one if detonation is present. Thats the key.
Then there is keeping the heads down when you approach a 400 shot. Many have had a hard time with this...especially with a 400 single stage.
You have to think about things like HOW your gonna spray 400? Staged? progressive....what octane...because you will certasinly need race fuel even with your low cmpression motor.
What are you gonna use for timing retard...this will absolutely be necessary. Do you have studs and MLS gaskets atleast? Hows your fuel system...is it up to par for your TOTAL hp amount. Or will you use a stand alone fuel tank with pump?
There is a TON to go through before you can MAYBE safely spray a 400.
Old Oct 25, 2007 | 03:27 PM
Damn i didnt think it was so hard to do so.
my car is making 520 whp & yes i wana spray with the supercharger there.
But i guess i should just forget about it.
Old Oct 25, 2007 | 03:32 PM
stainless40cal's Avatar
a 400 shot with the supercharger? hmm Break down of motor please? Im just going to say no because its probly going to go kaboom reguardless with that big of hit unless you have some serious people working behind this project...
Old Oct 25, 2007 | 03:35 PM
Ok then whats the biggest shot my motor can handle??
Old Oct 25, 2007 | 03:38 PM
383LQ4SS's Avatar
no...dont forget the idea. Nitrous works great with a SC'er. But just get a basic kit and start slow. I honeslty think you would be SHOCKED at what a lil ole 75 shot would do in conjunction with a supercharger.
Old Oct 25, 2007 | 03:50 PM
How about if i remove the S/C??whats the biggest shot can it take?
Old Oct 25, 2007 | 03:54 PM
383LQ4SS's Avatar
a 300 would be pretty easy.
But dont ditch the SC'er for now. Like I saud....even a 75 shot would probably get you 125 hp at the tires with a TON of Tq. i really think you would be shocked how much you would pick up. I dont think you would need to spray more than a 100 shot before you crapped your pants.
Old Oct 25, 2007 | 04:06 PM
AutoRoc's Avatar
What's wrong with people? The variables are...TOO MANY...You're trying to make the stars line up but you don't know what a telescope is.
If you have to ask this kind of question, you're obviously not qualified to do such a thing. UNLESS you like watching stuff break. Do some reading, punch some numbers after you've read too much...maybe it's what you're looking for. Anything is possible...you could even pay someone to do such a thing. Goodluck!
Old Oct 26, 2007 | 11:12 AM
Nitro Dave's Nitrous Outlet's Avatar
Like stated above a 400 shot would be way to much for your set up.
You would be suprised what a difference a 100 shot would make with your set up..
I personaly would put a wet 100 shot on the car. This will make hp two ways since you are adding power and cooling the intake charge.
Boosted applications tend to make more power than the rated hp due to the fact of the cooling affect.
Put a 100 shot on the car and slowly work your way up.. I think you will be greatly suprised on the difference it makes.
Dave
