Nitrous Line??
Old Nov 1, 2007 | 07:54 PM
greyghost4x4's Avatar
Banging some gears
Default Nitrous Line??
Does anyone here see why i couldn't use a Hydraulic hose for my nitrous line... as long it will hold the pressure and is the same size why wouldn't it work??? anyone tried this??
Thanks
Daniel
Old Nov 2, 2007 | 08:11 AM
Banging some gears
To the top!
Old Nov 2, 2007 | 08:22 AM
jmill96Z's Avatar
If you pressure test it , I don't see why not.
Old Nov 2, 2007 | 08:27 AM
slowprocess's Avatar
Thanks
Daniel
What size shot are you planning on running on your John Deere?
Old Nov 2, 2007 | 08:30 AM
Banging some gears
You shut your mouth when your talkin to me!!
BTW: im lookin to spary a 200hp propane kit on the tractor! LOL
Old Nov 2, 2007 | 08:32 AM
Banging some gears
Thats what i was thinking... Dad brought up the idea so i was curious wether or not it could work.. dont see why it wouldnt if it's the same size and will hold the pressure..
Old Nov 2, 2007 | 10:54 AM
TARZAN's Avatar
If I'm not mistaken, you'll need non-conductive hose, because N2O gets rather cold on its way out...And that will limit the strength of hose you can get from most places. your local NAPA should hve it good to 1300 PSI though
-Will
Old Nov 2, 2007 | 11:09 AM
COOKIE MONSTER's Avatar
Mississippi, uhhh, ok!
Old Nov 2, 2007 | 12:29 PM
Silver-Dollar's Avatar
Are you running propane or nitrous? Rubber hose is used for propane transfer in a lot of applications. It must be rated at a greater psi than your propane pressure, obviously.
Old Nov 2, 2007 | 03:35 PM
Banging some gears
haha. What i said about the propane was just a comeback to Slowprocess's response!haha
Old Nov 2, 2007 | 03:45 PM
jake2582's Avatar
i dont know if that would work or not? (i have considered it before)*
i know that some types of freon can go through a perfectly fine rubber hose. i think it is because the molecules of the freon is smaller than the hose mollecules or some crap? i may be wrong i dont claim to be a professional lol
Old Nov 2, 2007 | 07:09 PM
Randy WS6's Avatar
you need a Teflon lined braided 3000psi lined , The Teflon is for the extreme temperature change of liquid nitrogen and oxygen ,rubber lined hoses can not stand the extreme low temp. it well crack .
Old Nov 2, 2007 | 07:48 PM
koolrayz's Avatar
I used a hydraulic line for years and never had any issues. Filter was after the hose and never saw any sign of a problem
Old Nov 2, 2007 | 11:14 PM
TwoFast4Lv's Avatar
as long as it is teflon. Year ago I had problems trying to use other hydralich hose. I think it was freezing
