fastest roll to spray
Old Nov 5, 2007 | 03:02 PM
chevy0128's Avatar
Default fastest roll to spray
i have a 2001 z28 a4 ...what is the fastest roll you would want to spray the nitrous from. Could you do it on the highway from like a 60 roll?
Old Nov 5, 2007 | 05:27 PM
scottHMT's Avatar
sure. why not?
Old Nov 5, 2007 | 05:30 PM
95 Z28's Avatar
That'd be fine....I don't think the auto guys usually want to spray when they shift into OD tho, so you might want to cut it off before then.
Old Nov 5, 2007 | 06:23 PM
jmajorboner's Avatar
I sprayed a 175 at about 70, but I had a m6.
Old Nov 5, 2007 | 07:03 PM
chevy0128's Avatar
that sounds good i am racing my friends 07 350z from 60 to 120 or 130 and he doesnt no that i just got my tnt f1 kit installed.
Old Nov 5, 2007 | 07:16 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The A4 cars won't shift into OD at WOT
Old Nov 5, 2007 | 07:53 PM
mrr23's Avatar
really? don't tell that to my car then. done it since it was stock. been 151 mph.
Old Nov 5, 2007 | 07:56 PM
ChaseSS's Avatar
he is in for a rude awakening then
Authrom's Avatar
Shouldn't you win w/o the juice assuming he is stock..?
Old Nov 5, 2007 | 07:57 PM
scotts94_z28's Avatar
same here
Old Nov 5, 2007 | 08:35 PM
dpw41285's Avatar
same here my goes full tilt boogie right into od
Old Nov 5, 2007 | 08:49 PM
losiguy's Avatar
I don't know if the years differed but the majority of the A4's wont shift into OD at WOT stock without a tune to tell the PCM to let it too. I don't think its all that great on your stock trans either.
Old Nov 5, 2007 | 09:04 PM
Z28/2002's Avatar
From the Automatic section
Originally Posted by performabuilt
GENERAL TECH INFORMATION: 4L60/65E AND 700R4
2-Converter lockup.Lockup is controlled by the PCM. Full throttle lockup is not possible or preferred with factory tuning, but can be accomplished with PCM tuning. However, it may smoke the converter clutch prematurely.
Old Nov 5, 2007 | 09:21 PM
chevy0128's Avatar
well i think i would beet him but that thing has a quick ******* low end his tires catch so quick and i peel out for like a minute. But he is big headed with his 40k$$ car. I love taking him with my ls1 i bought for 11grand..and with the nitrous he will just trip
Old Nov 5, 2007 | 10:42 PM
BlackMagicC5's Avatar
Old Nov 5, 2007 | 10:49 PM
99_Z_155's Avatar
i dont think it really matters where you hit it from an engine stand point, as long as its over 3k up to your cutoff. ive shot from an 80 roll no problem. i am a 6 speed though.
Old Nov 5, 2007 | 10:51 PM
chevy0128's Avatar
when did you stop spraying at what mph?
Old Nov 6, 2007 | 09:50 AM
99_Z_155's Avatar
IDK, maybe 120. i dont know if i would want to spray to top speed. i would run out of juice fast. i guess sixth gear could handle it, i dont know.
Old Nov 6, 2007 | 01:15 PM
XLR8N's Avatar
if your on street tires i would say the faster the better, you dont want to over power the tires.
Old Nov 6, 2007 | 03:34 PM
Zero4488's Avatar
Restricted User
show him how an LS1 responds to the gas...haah
