Need Wiring diagram.....
Old Nov 8, 2007 | 05:22 PM
02blackbeauty19's Avatar
Default Need Wiring diagram.....
Most of the ones in the sticky have been deleted.
I need one for:
Wet shot
MSD window switch
WOT switch
FPSS
1st gear lockout
Bottle heater
Purge
I wired it up with some help of a few friends using a diagram last time but I am going to re wire it and put the 1st gear lockout and the FPSS on it. Thanks guys
Old Nov 9, 2007 | 08:18 AM
Bump for the day
Old Nov 9, 2007 | 12:31 PM
myfast70's Avatar
Just put the FPSS on the ground activation side of your replay. What type of 1st gear lock out switch are you using?
Old Nov 10, 2007 | 06:10 PM
^ I still would like to see a Diagram. I want to use a lockout microswitch like the one Robert56 uses. It just deactivates the nitrous with the shifter is in first and the switch is compressed
Old Nov 10, 2007 | 06:27 PM
jmill96Z's Avatar
It sucks all of the diagrams were deleted. I'm sure I remember seeing that one, and I'm looking to do something similar in my setup
Old Nov 10, 2007 | 07:46 PM
myfast70's Avatar
You should be able to just install it in between one of your relay activation wires and be fine.
Old Nov 11, 2007 | 08:50 AM
Yeah I know. Im not good at wiring, but if I visually see it then I am fine. I know I saw the diagram before
Old Nov 11, 2007 | 05:17 PM
Got what I needed.....
Old Nov 12, 2007 | 12:38 AM
aggiez28's Avatar
can you send it my way?
brook.foreman@gmail dot com
Old Nov 12, 2007 | 09:58 AM
Im actually at school right now and I have a couple saved on my computer at home. I just got them out of the sticky at the top. It showed almost everything I needed and for the 1st gear lockout microswitch, I just read Roberts instructions on how to wire it backwards.
