Help Quick Please, BMN Wiring...
got everything set up to what i thought was right so far. running an HSW single nozzle dry kit with a BMN w/s. i did as matt at HSW said and used the wiring diagram from the HSW instructions for the w/s and not the one from BMN. says to connect the black relay wire to the purple wire on the w/s. For the rest of the w/s wiring i used the BMN diagram. the nitrous solonoid is not opening at all when i hit my rpm window and yes the arming switch is on. did i forget something here??? i'm triple checking all my connections as we speak. Please someone help before i pull my hair out!!!
