Nitrous with BAP ?
Old Nov 13, 2007 | 07:09 PM
02blackbeauty19's Avatar
Default Nitrous with BAP ?
My stock fuel pump will be fine with just my heads/cam but i want to add a BAP that I can activate with a switch on my nitrous panel. Has anyone done this? and if so do you have any pics or write-up? Thanks
Old Nov 13, 2007 | 08:43 PM
Robert56's Avatar
Get the racetronics hot wire kit for your car and it has dedicated wiring plug for BAP, very simple. This can also up your stock pump by upwards of 20% capacity by suppling highest voltage direct from altenator. you could also do it by a simple relay tied into the wot sw to activate when nitrous is armed.
Robert
Old Nov 13, 2007 | 08:48 PM
^ thanks Robert! I knew what it does I just didnt know if it could be wired like that
Old Nov 13, 2007 | 09:22 PM
Robert56's Avatar
I was talking about the hot wire kit and the stock pump, not the bap concerning additional capacity.
Robert
Old Nov 13, 2007 | 09:30 PM
Yeah I planned on getting the RT harness also. I just didnt want to run the BAP all the time so I wanted to activate it with a switch on my nitrous panel
Old Nov 14, 2007 | 12:00 AM
Hennytime's Avatar
does adding a bap increase the injectors capacity as well since it increases voltage? shouldnt that increase pressure?
Old Nov 14, 2007 | 12:43 AM
383LQ4SS's Avatar
be careful with BAP on stock F body pumps...it will kill em quick IMO.
BAP will increase voltage...but its not increasing the voltage to the injectors that increases injector capacity...its the additional pressure provided by the pump that is run at higher voltage. Higher pressure at the same injector duty cycle equals more volume.
Old Nov 14, 2007 | 01:46 AM
This is for a 02 vette, but it may be the same pump as the F-Body. So if I am running SVO 30# injectors, that flow 36# at our FP, do they flow more when the BAP is turned on?
Old Dec 6, 2007 | 09:29 PM
Robert56's Avatar
Stock Vette pump is generally considered good to 500/550, and either or both (hot wire/BAP) can add capacity. Now i would go Racetronics, it is a better pump compared to the stock Vette Walbro, which is better than the F-bod stock pump. Check their site much info and explanation on how far and what to do concerning hp sought.
Robert
